You Know You Are Old When
/ You Know You Are Old When #1,102
Had a new roof put on the house and barn couple years ago.
There was a time when I never would have dreamed of calling someone else in.
I have become much more gravitationally aware as I age.
Too many older people kick off after breaking a hip in the bathroom. I don't want to do it from the second floor.
"gravitationally aware" I like that term.
/ You Know You Are Old When #1,103
Do pellets produce less creosote?
Essentially none. At least with the brand of pellets I buy (Golden Fire Premium Grade). I clean the stovepipe once a year in the summer and all I get is about a cup-full of fine gray powder. No buildup at the top of the stovepipe at all like I used to have when burning wood.
/ You Know You Are Old When #1,104
One of the reasons I went from a wood-burning stove to a pellet stove. Don't have to climb up on the roof once a month to clean the stove pipe.
We do ours once a year. I've learned how to do it from the bottom just in case I can't get on roofs anymore.
/ You Know You Are Old When #1,105
Same here. Bought a brush kit with the flexible rods; keep adding rods and turning the kit with a drill motor. Look up into the stovepipe with a mirror after I'm done and the pipe is clean and shiny all the way to the top.
/ You Know You Are Old When #1,106
I'll still go up on a 10/12 roof at 63 if needed but I'm not as comfortable as I once was.
/ You Know You Are Old When #1,107
36"x12' Stacks of Sheet Metal (A60463)
36"x12' Stacks of...
Bobcat 435 FastTrack (A60462)
Bobcat 435...
2019 FORD F-150 XL CREW CAB TRUCK (A59823)
2019 FORD F-150 XL...
light tower (A60352)
72" Grapple Attachment (A60462)
72" Grapple...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
