Poison Oak Everywhere!
/ Poison Oak Everywhere! #1
ajllynco
Ford 1710
I recently bought 3 acres of which 1 acre is completely infested with poison oak. I'd like to start prepping the ground for planting Bermuda, fence it, and turn out my 2 horses there. What can I do to get rid of the poison oak? I have a JD 3032e and numerous implements. TIA
/ Poison Oak Everywhere! #2
/ Poison Oak Everywhere! #3
Foliar spray Triclopyr works well on poison oak when its growing. The advantage is that it won't kill the grass. 2,4d will kill everything.
If your PO is in tall bushes or even short ones you need to rip it out or mow it down first. The best time is in the winter when the leaves are off. The stems still contain Urushiol but there's a lot less surface area to spread it. I'd still stay well away from the mower and take all precautions afterwards such as washing any exposed skin. Whatever you do, don't burn it. The smoke will do to your lungs what the leaves do to your skin.
Once you have the bushes removed you can go over the area in spring and summer with Triclopyr. You'll have to keep at it for a number of years to kill the roots underground and exhaust the seed bank.
For large plants I use 25% Triclopyr in oil. Applied to a short section of stem, it soaks in and kills the plant in a month or so.
/ Poison Oak Everywhere! #4
Where are you located? not that it matters, I'm just curious. I don't know how familiar you are with poison oak so if you forgive me if I am telling you stuff you know. First of all don't burn it. Second, all parts of the plant are poisonous. Even dead roots can cause problems. If you are cutting unknown roots and the cots turn black after a few hours then they are poison oak. My Younger brother, who knows all about plants, uses Roundup, I think. Anyway, I'll shoot him an email and ask what he does to get rid of the stuff.
Eric
/ Poison Oak Everywhere! #7
My Irish Dexters love that stuff.....
/ Poison Oak Everywhere! #8
24D will not kill grass. It is only active on broadleaf plants. Roundup (glyphosate) will kill any green growing plant including grass.
/ Poison Oak Everywhere! #11
If you're not a toxic avenger, goats or hand-pull when the ground isn't dry. It comes out fairly easily and if you get a decent amount of the roots it doesn't come back.
Just pile the stuff up off to the side, it breaks down in about a year. Definitely don't burn it, I once had a single strand of the stuff in a burn pile and I was coughing for weeks.
/ Poison Oak Everywhere! #12
First and foremost make sure it's poison oak then use products marketed specifically for killing it and read the label,,,,twice. Some chemicals kill it but are less effective and/or efficient than others. Some kill it but kill desirable plants as well. Heavy grazing is hands down best solution. Loan land rent free to a goat raiser until old growth is gone then cattle and sheep will control new growth in the future.
/ Poison Oak Everywhere! #13
No it doesn't kill everything! Read the label!
Its a broadleaf herbicide. It attacks plants with a round cell structure rather than a parallel structure like is found with grass. It doesn't kill your grass. If you want to kill everything use Glyphosate which kills trees too including stumps. I've been using it for decades and it alone has killed off all my poison oak nuisances and when I bought the place it was rampart.
/ Poison Oak Everywhere! #14
Yep
/ Poison Oak Everywhere! #15
I guess you missed my post on Nov 30 where I said that I was mistaken about 2,4d and had been thinking about Roundup.
/ Poison Oak Everywhere! #16
Some people are immune to poison oak, and can cut, pull, or dig it without risk.
It is not recommended to burn it.
/ Poison Oak Everywhere! #17
It's the bane of my existence even tractor work when it's dusty will give me a case at the neck.
It's taken years to tame with a shear for the coke bottle size stems and Ortho Brush B'gone... don't know if still around.
It's very tenacious in that some ares have taken several seasons to eradicate.
There is s family if Samoans here that specialize in removal... never seen anything like it the way they rip it out and they get big bucks for the work...
It can be done...
/ Poison Oak Everywhere! #18
Poison Oak, is a vine. Find all the leaders to the upper canopy and cut them.
/ Poison Oak Everywhere! #19
Here its mostly in vine and bush form
The clear sap oxidizes black like a sharpie marker
Had a 50 cent stain on a pant leg...
Didn't know at the time and put all the clothes in for a double wash.
A few weeks later put the same pants on when I pulled an engine and it was then I got poison oak... the wash cycles didn't remove the oils...
/ Poison Oak Everywhere! #20
I am one of the lucky ones no reaction to any of that stuff. At least my oldest has the same skin. We can pull that stuff bare handed with no ill effects. However if he touches the pink insulation it's all over, don't bother me a bit.
International S1900 (A63118)
International...
John Deere 652R 52in Stand-On Commercial Mower (A56857)
John Deere 652R...
CATERPILLAR T40D STRAIGHT MAST FORKLIFT (A62129)
CATERPILLAR T40D...
KUBOTA MS-111 TRACTOR (A62130)
KUBOTA MS-111...
20 Yard Dumper (A61166)
20 Yard Dumper...
2009 Vanguard National Dry Van Trailer, VIN # 5V8VA53259M900716 (A61165)
2009 Vanguard...
