CK2610H/3510H Misleading Owner’s Manual Data ‘Rated RPM’
/ CK2610H/3510H Misleading Owner’s Manual Data ‘Rated RPM’ #1
toukow
Seattle,WA
2019 Kioti CK2610HST, Ford 1700 (Gone)
From time to time, my tractor has been having issues of reaching rated PTO RPM, which I’ll post about separately. While looking into this, I found errors in the Kioti CK2610/3510/4010 owner’s manual. My owner’s manual is dated JUL 2018, so perhaps this has been corrected in later versions. My downloaded scanned version is the same.
When something is stated as ‘Rated RPM’ without any qualifiers, I assume it’s the maximum allowable RPM for the engine. My manual shows ‘Rated revolution’ on Page 3-4 as follows-
CK2610 2,400
CK3510 2,600
My engine was exceeding this value. I looked in the factory service manual for my CK2610H with 3A165 engine and found the following bits
Page 2-6 Repeats the above information for both models
Page 3-230 :
CK2610H Max/Min. rpm 2,600/1,150 +/- 50, so a maximum of 2550-2650 RPM maximum
Gross Power HP/RPM 24.5/2,400
Page 3-9
CK3510H Max/Min rpm 2750/850 with no +/- value indicated
Max Gross Output HP/rpm 34.9/2600
So the owner’s manual is stating the RPM for maximum horsepower, not the maximum PRM rating of the engine.
Most won’t care about the variance, but some may. For what it’s worth, Toukow
/ CK2610H/3510H Misleading Owner’s Manual Data ‘Rated RPM’ #2
Right, the term "rated" means the engine speed at which maximum power is reached. IE the engine speed at which is is "rated" for its HP output.
It's no problem to spin the engine a bit faster than rated, but there's also no real reason to do so on a tractor. Sometimes I spin up to max rpm when trying to lift very heavy things with my front loader, or when I want to drive as fast as possible.
The engine controls are not going to let you rev the engine higher than is safe for it to go; nothin to worry about.
Sorry for my confusion.....
/ CK2610H/3510H Misleading Owner’s Manual Data ‘Rated RPM’ #4
the quality of Kioti owner's manual is so bad
in Owners-Manual-DK20-Series-US-230922-1.pdf there are so many errors, e.g. conflicting references of DK6020 fuel tank size (12.7 vs 11.9 gallon).
2007 Avanti 36 Boat with Tri-Axle Boat Trailer (A59231)
2007 Avanti 36...
(INOP) 1996 CASE 580L BACKHOE (A59823)
(INOP) 1996 CASE...
KJ K2223 23'x22' Metal Shed (A60463)
KJ K2223 23'x22'...
PALLET OF 15 4X8 GROUND PROTECTION MATS (A58214)
PALLET OF 15 4X8...
2002 Kenworth T300 TMA Truck (A55973)
2002 Kenworth T300...
UNUSED INDUSTRIAS AMERICA HYD POST PULLER (A60430)
UNUSED INDUSTRIAS...
