Lucas injector pump swapped to Bosch mechanical pump
   / Lucas injector pump swapped to Bosch mechanical pump #1
Treemanbbs
2002 new Holland ls180
The temperamental and very expensive Lucas pump ($3850 ) was unrebuildable so saw some guys we’re replacing with the old mechanical Bosch pump. I installed a new Bosch pump. Had the injectors recalibrated. Replaced the drive gear and rerouted the hard lines. Installed new lift ( supply ) pump and new filters. The engine idles great but only a small amount of rpm change when throttled up. I have in the past installed a primer bulb like boats have to prime it. If I squeeze the primer bulb when it’s running it does raise the rpm a slight amount. I have taken the linkage off the pump and moved the throttle manually with no change. Acts like it’s starving for fuel. Any ideas ?
   / Lucas injector pump swapped to Bosch mechanical pump #2
Is your lift pump really functioning, that is pretty basic to supply fuel to injector pump.... Also is injector pump timed correctly?
Yes the supply pump is putting a lot of fuel to the filter housing at the bleeder plug. As far as timing, I had the engine set per all the specs and the pump was locked to install. But with the minor adjustments you can make by twisting the pump housing ( like you would do a distributor) the hard lines won’t allow very little movement. Does that adjustment affect the timing much ? I could remove the hard lines and adjust pump and rebend the hard lines to fit again.
   / Lucas injector pump swapped to Bosch mechanical pump #4
Although I pumped the primer bulb with little to no change, a CAV feed pressure is only 1-3 psi.. Feed pressure to a Bosch in-line pump is 25 psi to feed all the pumping plungers..
WHAT KIND OF CAV cost $3850.??!!!
The Lucas that is oem was $2850 last year when I did the swap. And walla go I just decided to get give up and buy one and an ebay listing had it for $3850.
So Pump Guy , if you are saying the original Lucas pump only needs 1-3 psi to supply it. And the old style Bosch needs 25 psi. Can you tell me what sort of lift pump I can install to get the 25 psi ? The setup I have now is the lift pump is mounted directly on top of the fuel filter housing.
   / Lucas injector pump swapped to Bosch mechanical pump #7
Let’s start with some pictures of the pumps or at least some pump #’s..
I gotta know what I’m working with..
This is what is originally supposed to be on the ls180 new Holland skid steer.
This is the injector pump I installed that was original to early seventies ford 3000 tractor.
2019 Chevrolet Tahoe SUV (A49461)
2019 Chevrolet...
DOG HOUSE/CONTAINMENT SLID (A50854)
DOG...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51222)
2018 FREIGHTLINER...
2000 MACK RD688 TRI AXLE DUMP  TRUCK (A51222)
2000 MACK RD688...
2013 LACROSSE LUXURY LITE TOURING EDITION TRAVEL TRAILER (A50854)
2013 LACROSSE...
2019 CATERPILLAR D5K2 LGP CRAWLER DOZER (A51242)
2019 CATERPILLAR...
