Whining
/ Whining #1
confederatemule
I bought a new Kioti CS2220HS last month. It sounds fine till I press the forward or reverse pedal. At that point it starts whining. Any time the tractor is moving it whines, the faster the louder. The transmission fluid is on the full mark. It seems to do the work it is supposed to do, it just sounds like the brake is applied, but it is not. To make sure I have taken it out of gear and it will free roll forward or backward. Is this sound normal?
To me it sounds like a hydraulic pump that has reached it's limit and the relief valve is squealing as the pressure is bypassing through it.
Mule
/ Whining #4
That sounds normal. When I did my first hydraulic/HST filter change, I also replaced the fluid with MOBIL 424. Much quieter after that.
Patrick
I am going to try the Mobil 424 (aka Mobil Del Vac) with my 1,000 change. My dealer recommended Wolveshead and it whines worse than Traveller from TSC.
/ Whining #5
Mule
Hydrostatic transmissions will whine. I was surprised how loud mine was compared to hydrostatic riding mowers I've had in the past. At your 50 hour service I would replace the fluid with Mobil Delvac/424, even though it says you only need to change the filter. It's cheap insurance and it should quiet the whine considerably.
/ Whining #7
Yep, whine is normal. I actually decided to sell my LS MT125 because of the whine. Went back to a shuttle shift to get away from it..... used to make my ear drums squeal....
/ Whining #9
My MX Kubota only whines when I work it really hard. Reminds me to choose a lower gear, 4 wd, or otherwise reduce the load.
/ Whining #10
Hydrostats are touchy when it comes to fluid. I would NEVER use cheap Traveller fluid in any hydrostat. Only thing that stuff is good for is starting burn pile fires, least in my opinion
/ Whining #12
....I guess this one is related to hearing and personal musical tastes.
This my first HST tractor and to be honest I do not notice a sound/feel/performance that seems odd. Honestly it feels every bit as solid in movement as a gear/shuttle tractor ......with the added benefit of not attempting to ride-the-clutch when you need some small forward or reverse movement.
I actually prefer the HST pedals plus brake for small maneuver movements and do not notice any concerning whining from the HST transmission. The HST operation seems very solid to me.
I did my own 50hr service at 35hrs changing out both filters and new Kioti THfluid (even thou the dealer said I could reuse the original). I used Kioti fluid to avoid a 'discussion' if there was any future transmission warranty issues. The only thing I noticed in doing the service was that both filters where torqued on way too tight and likely without lube on the rubber seals. It was not easy getting the factor filters off.
When I did get them off I opened them up to see what they collected - no metal shavings - just some bits of silicone gasket sealant.
No concerns here, so far, about the HST operation.
2023 with 145hrs.
/ Whining #13
That is interesting to hear that there was no metal in the filters..my dealer said not to worry about filter change untill 200 hour mark on my ns5310. I bought the filters anyways but haven't put them on yet..tractor is at 70hours..these filters cost so much I'm on the fence about waiting a little longer now..
/ Whining #14
.......hmmmmm .......my long term experience with engines is that the first filter change is better sooner than later and it is worthwhile cutting them open to have a look-see for what is there. The build process for an engine is not perfectly clean and there is always some material that gets inside. If you see metal in the first filter, best to check the second filter to ensure it was just build debris and not excessive wear.
Once you know your clean, then you can choose to extend the interval if you want.
In theory, you should never have a wear problem in a new engine, but I have noticed over my life that theory and reality can be different. Any manufacture process will have a failure rate - in theory very small.........but in my 2023 CS the failure was a head flange that was not machined down enough and contacted the valve rods when at operating temp. One valve rod eventually broke after 100+ hours. Not enough metal to notice in the oil filter, but enough heat stress on the rod to eventually crack it.
Fortunately the rod broke in a place where the valve could not drop into the cylinder and "F" the entire engine. The top of the rod just dropped into the valve oil well.
They have 'warranties for a reason' as no mass production process is perfect.
/ Whining #15
I did change the engine filter at the 50 mark..it was only the hydrolic and hat filter that my dealer said to wait till 200h
/ Whining #16
The oil for whatever needs oil is SHELL Rotella for the engine, SHELL S3 grease, CASTROL 90 weight gear oil, I am not sure off the top of my head what hydraulic oil I am using but I think it is PETROCAN 90 weight. They own SUNOCO up here.
/ Whining #17
2023 with 145hrs.
Currently my 2012 CK27hst has 1220 hours on it and it has whined since day one. I asked the dealer about it and he said that some do and some don't. Don't sweat it, just turn the stereo up louder. So after the warranty was up I put a straight pipe on it. Now I got something to listen to. Through the exhaust note I can hear when I am lugging the engine down. The hydraulic relief valve starts to squawk, too.
I run SHELL in most everything I own.
I used to run Sun oil products until Petro-Canada bought them out. I do not shell out my hard earned scheckles to P-C IF I can possibly help it, but I am pretty quite sure that it is SUN-OIL gear oil I am using.
/ Whining #18
My TYM isnt the first hydro tractor I've run, but it is probably the quietest. I can't hear it over the tractor. From this thread I've learned not to cheap out on the hyd fluid during the first change this year.
/ Whining #19
This is what I use in my 2014 CK30HST. Currently close to 600 hours on the Amsoil Synthetic Tractor Hydraulic/Transmission oil. Runs quiet and even in the cold Canadian winter months the hydraulics act like it’s summer. Not cheap but the long drain interval helps…
1 PALLET OF JACK & IMPACT GUNS (A66091)
1 PALLET OF JACK &...
DRAGON 500BBL WHEELED FRAC TANK (A67714)
DRAGON 500BBL...
2013 FORD F-150 (INOPERABLE) (A67714)
2013 FORD F-150...
2019 CATERPILLER 249D SKID STEER (A65056)
2019 CATERPILLER...
2014 FREIGHTLINER M2 4X2 S/A CNG FLATBED WITH CRANE TRUCK (A66091)
2014 FREIGHTLINER...
2015 Freightliner M2 106 Hawk H-1150TL Forestry Grapple Truck (A66736)
2015 Freightliner...
