Tekumseh enginge shuts down when blades start spinning
   / Tekumseh enginge shuts down when blades start spinning #1
AlexanderRuskov
MTD Lawn Traktor
I have a problem with my tractor mower. When the blade are lowered, revs begin to drop and the mower shuts off.
The traktor has 2 blades.
The engine is tecumseh, 12hp.
The carburetor is cleaned and the spark plug is sparking.
If anyone knows anything about the problem, please write.
   / Tekumseh enginge shuts down when blades start spinning #2
AlexanderRuskov​
Welcome to TBN.
Can you give us a little more information on your tractor ?
Is it the MTD that you have listed in you bio or something else ?
What is the tractors year of manufacture ?
Can you give us the model number of the engine ?
Richard
   / Tekumseh enginge shuts down when blades start spinning #3
Make sure you have no excess drag on the blades, spindles, or belts. Check the brake used to stop the blades from spinning. Does the engine have one cylinder or two? If two cylinders are you sure both are running?
AlexanderRuskov​
Welcome to TBN.
Richard
Hello,
thank you for the fast reply!
Tomorrow i will check the year and the model of the engine.
Thank you,
i`ve checked the blades and the belts. They seem pretty fine. i have also checked the safety switch.
   / Tekumseh enginge shuts down when blades start spinning #7
check that the blades turn by hand with motor turned off. Then check electric clutch IF it has one, (these can lock up). Make sure nothing is getting in a bind. sounds like something hitting somewhere.
i wil post photos of the engine and the tractor tomorrow. will try to post a video too.
   / Tekumseh enginge shuts down when blades start spinning #10
I have a TroyBilt riding mower, and the engine will die if I have the blades engaged and shifter in reverse. There must be a safety switch that doesn't allow me to mow in reverse. Maybe your MTD has the same system and the switch is stuck closed?
Patrick
2019 CATERPILLAR 326FL EXCAVATOR (A51242)
2019 CATERPILLAR...
Agco Hesston 4590 Square Baler (A50515)
Agco Hesston 4590...
2024 CATERPILLAR 299D3 XE SKID STEER (A51242)
2024 CATERPILLAR...
2025 GIYI Single Cylinder Hydraulic Grapple Stump Bucket Skid Steer Attachment (A50322)
2025 GIYI Single...
2006 GMC C7500 DUMP TRUCK (A51406)
2006 GMC C7500...
Walking Floor Trailer 43ft (A50322)
Walking Floor...
