what on earth does electricity cost near you?
   / what on earth does electricity cost near you? #811
In my area power is supplied by TVA. $36 monthly service charge plus 11 cents/kwh
   / what on earth does electricity cost near you? #812
About .15/kwh... That does not include all the additional fees and surcharges. That is just the rare per kwh.
Our all electric home and shop in central IN costs about $150-$180 per mo every month.
That would be ground-source ? Can't see resistance-heating, @ your latitude/kwh rate.
Assuming other than, Tiny Home, Tiny Shop.....:cool:
Rgsd, D.
   / what on earth does electricity cost near you? #813
I recall TVA supplied power to our plant back in the early 90’s being about 4.5 cents/kwh. We used over a million kWh a month so we got a little discount. A million gallons of water per Day too. It takes a lot of utilities to process chickens.
   / what on earth does electricity cost near you? #814
Rgsd, D.
We don't use resistance heat. The shop has no heat. It only has lighting, and the most power hungry item is a large dust collection system. It's 40x60. The home (1800 sq ft) has a heat pump. The resistance heat only fires when we drop below 5F
   / what on earth does electricity cost near you? #815
If anyone wants deep insight into that ^, read Alex Epstein's book, Fossil Future.
Excellent book. Read it last year. Everyone should read it. Gives a balanced look at energy sources and tradeoffs.
   / what on earth does electricity cost near you? #816
Currently $0.32 per kw😡
Imagine paying $7.68 if you left 1 100 watt bulb on 24 hours!!
Massachusetts has passed into law that new 2024 construction requires a 400 amp service with no propane appliances!!
As usual lawmakers are passing laws without thinking about implications. Where’s this power coming from??
90cummins
I dont follow that math?
100w bulb running for 24 hours is 2400w/h or 2.4kwh
2.4 x $0.32 dont equal $7.68 So what am I missing here? You have the decimal place a notch off
   / what on earth does electricity cost near you? #817
That's what I was thinking. 77 cents would be more like it.
   / what on earth does electricity cost near you? #818
My "rough estimate" calculation has always been:
at $0.10 per KWH,
one watt used for one year cost $1
100 watts for one year (constantly on) costs $100
At $0.30 per KWH the cost goes to $300
So, 300 divided by 365 is a little less than $1 per day,, (~$0.82?)
We sorta agree!! (y)
   / what on earth does electricity cost near you? #819
"Northern VA"
.11 per kWh
Averaging 3000 kWh a month.
   / what on earth does electricity cost near you? #820
Recent bill:
$ 0.19 CAD / kwh : direct cost, before our VAT applied.
^ doesn't include, a Provincial rebate (for now) that amounted to $0.045 / CAD kwh. So, since I'm going to be paying for that rebate one way/another..... I'm more like $0.235 CAD / kwh.
Rgds, D.
2015 Chevrolet Cruze Sedan (A55853)
2015 Chevrolet...
Pallet of UV Solid Hardwood Flooring (A53424)
Pallet of UV Solid...
2016 Ford Transit 250 Passenger Van (A55852)
2016 Ford Transit...
2018 Kubota U17 (A53317)
2018 Kubota U17...
2003 Ford F-350 4x4 Altec Service Truck (A55852)
2003 Ford F-350...
