Welding a Reese tube to a box blade
   / Welding a Reese tube to a box blade #1
RadarTech
Elite Member
North Carolina
2007 Kubota L3400, YANMAR YT359C
I’m looking at doing those to jockey trailers and not have to swap out to the 3PH Reese adapter.. thoughts?
   / Welding a Reese tube to a box blade #2
I've seen this done. It works okay.
   / Welding a Reese tube to a box blade #4
Are you wondering how to mount it or asking if it's worth doing?
   / Welding a Reese tube to a box blade #5
i did this to my BB so I could move small trailers & wood splitter around my place.
Probably way overkill, but I like to weld.
   / Welding a Reese tube to a box blade #6
That's the way to do it. I've seen where folks just welded them to the blade in back and ended up twisting things.
   / Welding a Reese tube to a box blade #7
I have receivers added to box blades and regular blades. But I flush mount them on box blades.
   / Welding a Reese tube to a box blade #8
Hitch was handy for moving lite trailers around. Welding extra supports and hitch also helps cheap box blades. Use hitch on box blade to store hitch crane. Don’t use the box blade much after the land plane.
   / Welding a Reese tube to a box blade #9
Receivers on box blades can be handy for more than light trailers.
Running the rippers all the way down on both of these saves a fair amount of time, and it doesn't hurt that the little 7-footer in the back has its rippers right between the ones on the 8'.
Same with just spreading/leveling dirt...pulling both at once helps.
   / Welding a Reese tube to a box blade #10
Go for it. I got a clamp on one I clamp onto my bucket cutting edge for this which works quite well.
   / Welding a Reese tube to a box blade #11
Same with just spreading/leveling dirt...pulling both at once helps.View attachment 852979
Interesting rig, looks like it would take a bit of experimentation to get good with it. Any movement on the first gannon would change the angles on the second gannon which also has it own adjustment
   / Welding a Reese tube to a box blade #12
Set everything out, look at it, think logically, then just kinda wing it. Who's to tell ya it's wrong? If it don't work, modify and Binford, can't go wrong.
   / Welding a Reese tube to a box blade #13
Yeah, depends on how precise I want the result to be. Generally both are only used together for ripping and rough grading.
Basically I set the side angle to what it should be with the hydraulic side link, then adjust the first one with the 3-point and hydraulic top link. That leaves the second one at whatever height/angle it is, since only the axle height is adjustable.
If being picky, I could use a low, straight, or raised, pintle hook mount, but it's easier to use a 5-foot extension between the pintle and second box blade, making it less sensitive to the height of the pintle hook. That also helps a lot when pulling only the little one by itself.
Also, the second one can't really be lowered and used until the first one has established the correct side angle, since what the second blade cuts is the angle it'll keep creating, with the tires blindly following its own cut.
All this would be much simpler if the ground here was flat, but because of the irrigation ditches it is not. Fighting mounds (mini ridges, really) built up over decades by prairie dogs is what most of my grading is all about. It's a bit of work, but easier than trying to make water flow uphill.
   / Welding a Reese tube to a box blade #14
I welded one on the cross beam for my SSQA. I just remove the bucket and put a ball mount on so what ever attachment is on the front or back I still have acess to it without putting something else on.
   / Welding a Reese tube to a box blade #15
I have one box blade that has a 2" receiver welded into it but I really don't use it much. If I am pulling dirt I generally use just the box part, that I cut the 3 point off of.
If I want to smooth it out, I use the 3 point part off that box that I converted into a land plane. I did weld and extra section of angle the back of it and mounted 2" ball.
Its a lot more useful as its easy to see where I am at from the seat of the tractor, if I am just moving stuff around, I don't even need to get off the tractor. Certainly don't need to to ensure alignment.
2022 Polaris Ranger 900XP 4x4 Utility Cart (A55853)
2022 Polaris...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59905)
2019 FREIGHTLINER...
2016 FORD F550 CREW CAB SERVICE TRUCK (A59905)
2016 FORD F550...
2014 International Derrick Digger Truck (A55973)
2014 International...
2019 GALYEAN...
John Deere 5045E for sale Auction
John Deere 5045E...
