SC2400 no power when cold *bonus SB52 pic*
/ SC2400 no power when cold *bonus SB52 pic* #1
PViL
Yanmar SC2400
425 hours, lately it has been more difficult to start. Normally it would start right up and go. Now it starts maybe 2nd try and runs rough for the first 30 sec or so. It will idle up to full RPM but falls flat with any load and will almost stall. I normally idle around 1K and warm it up 5 min before moving. After running at a fast idle (1200 RPM) for about 25-30 min it will work normally. I am not sure if I am getting full power, but everything seems to be working once it is hot. I have changed the air filter and the fuel/water separator filter. Where else should I look?
/ SC2400 no power when cold *bonus SB52 pic* #2
@msb1766 Thanks!
It was the fuel filter on the other side of the pump. Pretty easy fix. I ordered the new filter and when I went to change it, I found the one I had bought a few years ago. Now I have a spare. 😒
I also noticed in the manual the part about not storing fuel in galvanized containers. The metal fuel can I was using has been replaced with plastic.
It runs great now.
/ SC2400 no power when cold *bonus SB52 pic* #4
@msb1766 Thanks!
It runs great now.
You are 100% correct. do not use cans nor tanks with galvanized metal.
Yanmar mentions this for their Marine engines too. When I'm at estate sales, I've come across old and imported galvanized Gerry fuel cans. Nope, nada, do not buy them nor want them. And if they are painted on the outside, use a tactical pen light to look inside.
Even if the Gerry fuel can looks safe, check the cap!
For diesel, these are ideal, just keep them out of direct sunlight.
/ SC2400 no power when cold *bonus SB52 pic* #5
Too bad they have the lousy EPA mandates spouts. Some brands are worse that others but they are all somewhat bad.
/ SC2400 no power when cold *bonus SB52 pic* #6
Yep.
I have a few of the 1st gen EPA spouts Blitz made. Those are the only ones that really work. The new ones today are really crap.
When I spot any of those early Blitz cans with the right spout at garage sales, I tend to snag them.
My tractor model has the diesel fuel cap atop of the hood. Its sort of a pain at first to fill, yet now I have a system to not waste fuel nor get it all over the place.
This is the only workable one out there,
I do not like the dumb spring loaded on the Stens, I make a mess every time and waste fuel,
And the really stupid ones with the base green twist neck are the worse, B+S uses it all the time.
Red Cedar Glider Chair (A61569)
Red Cedar Glider...
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58214)
RAKE ATTACHMENT...
1990 Lufkin CM-320D-305-100 Road Runner Mobile T/A Oil Field Pumpjack (A60352)
1990 Lufkin...
2017 Ford F-150 Ext. Cab Pickup Truck (A61568)
2017 Ford F-150...
Woods BB72 72in Rotary Brush Cutter Tractor Attachment (A61567)
Woods BB72 72in...
2014 Vermeer Vac-Tron MC533SDT Heavy Duty Vacuum Trailer (A60352)
2014 Vermeer...
