Black soot and smoke but no “spark”
   / Black soot and smoke but no “spark” #1
skipatroldude
Jd 3320
Turned off my tractor and now it won’t start . Turns over fine but just black smoke and soot. It is below 32 degrees also. Engage glow plug and looks like it works but the light doesn’t turn off after 10 seconds. Ideas? Thank you.
   / Black soot and smoke but no “spark” #2
Is it gas or diesel? If gas, your engine will blow up very soon.
   / Black soot and smoke but no “spark” #3
Glow plugs and gas? Yep, that's an explosive combination! :)
Kidding aside, the first thing I'd do is check the fuel. Is it fresh, winter fuel? Any water or ice. Make sure fuel is flowing freely through the filter(s). If possible, use a heater to warm up the tractor.
If the fuel is good, the airbox heater and/or glow plugs may be defective...depending on how far below 32 degrees. Many diesels fire up just fine reasonably below 32 degrees without glow plugs or airbox heaters.
Battery in good shape?
   / Black soot and smoke but no “spark” #4
How to keep the soot away and ways to prevent having the head warp and crack on these Yanmar engines.
- Do not let the engine idle below 1200rpms for longer than 10mins max at a time. And the time is with 20mins between.
- Do use 10W30 summer and 5W30 winter for engine oil. Do not use the heavy thicker 15W40 as it will holds the heat longer in the engine. Yanmar makes engines to JIS standards, not SAE. So the cooling oil passages are narrower in metric.
- Do keep the air intake filter clean. Clogged filter makes the engine work harder and heat builds up with the engine.
- Do keep the radiator and the screen clean.
- Do check the coolant. Do not use extended life coolants in these vintage machines.
- Do start the tractor slightly above idle.
- Do not race the engine from slow to fast and fast to slow.
- Do slow the engine speed down gradually, idle for 15 seconds then turn the engine off.
Some of these tips are from Deere, some are in the Yanmar USA bulletins and some came from the Yanmar JP website before 2018.
   / Black soot and smoke but no “spark” #5
The title of the thread said NO SPARK. ;)
   / Black soot and smoke but no “spark” #6
Put a full charge on the battery
Put a heater or a hair dryer on the engine for a while (15-30 minutes)
Try to start it
Thanks I’ll try and put new fuel in it. New battery and I have it hooked up to my truck with jumpers.
   / Black soot and smoke but no “spark” #8
Try to start it
I've put a hair dryer or heat gun directly into the intake to give the engine some warm air and it seemed to help. That was when I think I may have been having some glow plug problems.
Start evaluating the glow plugs? Power to the plugs? Resistance in the plugs?
2016 Snorkel S4732 Scissor Lift (A57453)
2016 Snorkel S4732...
New/Unused Agrotk Wood Splitter (A57453)
New/Unused Agrotk...
2007 STERLING TRUCK L9500 CHEMICAL TRANSPORT TRUCK (A58214)
2007 STERLING...
2019 Ford F-550 4x4 DurALift DTAXS39 39ft. Bucket Truck (A55973)
2019 Ford F-550...
2012 VOLVO VNL (A55745)
2012 VOLVO VNL...
Mower King Brush Cutter (A53317)
Mower King Brush...
