ArlyA
Super Star Member
- Joined
- Mar 18, 2016
- Messages
- 13,305
- Tractor
- Outlander1000 6x6, Ego lawn mower and shopping for tractor
Pond hockey seen here. Its about 30ft deep!
2" over your mouth and nose is all it takes.Pond hockey seen here. Its about 30ft deep! View attachment 850221
If the ice was checked and deem safe why depth matters ? 4 inch is all someone need to go on, on foot.Pond hockey seen here. Its about 30ft deep! View attachment 850221
The deeper the water the longer it takes to recover the body(s).If the ice was checked and deem safe why depth matters ? 4 inch is all someone need to go on, on foot.
Recover or not it doesn't change the outcome, we go on rivers out here and there's very little to no chances for body recovery if one goes through... the point is as long as there's a safe amount of ice the depth is irrelevant sine you wont go through.The deeper the water the longer it takes to recover the bodie(s).
I'm not sure what the water temp is in the canal today but the current is quite strong. Body's aren't found for years so it must be cool.The deeper the water the longer it takes to recover the body(s).
Water cannot be colder then 32 degrees FI'm not sure what the water temp is in the canal today but the current is quite strong. Body's aren't found for years so it must be cool.
There's no such thing as safe ice.Recover or not it doesn't change the outcome, we go on rivers out here and there's very little to no chances for body recovery if one goes through... the point is as long as there's a safe amount of ice the depth is irrelevant sine you wont go through.
Yep. From what I understand, cold water slows the decomposition process, and slows the body from producing gas during the decomposition process. That gas, when produced, bloats the corpse and helps it rise. Couple that with the fact that most humans reach negative buoyancy right around 30', and Bob's not your uncle.I'm not sure what the water temp is in the canal today but the current is quite strong. Body's aren't found for years so it must be cool.
