What did you do at work today?
/ What did you do at work today? #341
Selected tile for the back splash and Showers for our new house build. Started looking at Hickory flooring and made a couple of recommendations to my wife and the design specialist helping us.
/ What did you do at work today? #342
Worked like the dog I am at my home business.
I have work so life is good.
I have too much work, Ugh, but my wife is happy.
I guess life is still good :giggle:
/ What did you do at work today? #344
Snapped bell housing bolts on a 12" pump. Dropped the belt guard and wiped out a drive belt for the vacuum pump.
Gonna be a fun day
/ What did you do at work today? #345
ouch, not a good start.
/ What did you do at work today? #346
This one has been sitting for a few days. pulled it out of the jobsite Monday. But put off tearing into it until I ran out of other projects
Today I had to put my big boy britches on, suck it up and tear into.
I actually got the pump end removed. The bolts that snapped off flush extracted already. Fixing to get the vacuum pump belt replaced. Then after lunch, I'll run over to a bolt vendor, get some grade 8 or 10 bolts to replace all of them for the bell housing. Then I can put it back together.
/ What did you do at work today? #347
Maybe tread lock blue which has always provided easy removal years later if you can't use antisieze?
/ What did you do at work today? #348
Replied to 6 Emails. Checked the usual websites. Responded to two. Made breakfast for wife and fed the dog. Then walked dog. Changed batteries in the surveillance trail camera and loaded all the pics off the SD card. Paid two bills on line. Looked up a recipe that used tortilla chips and canned tuna fish. Watered the garden and started the water refill of our fountain. Took out several annoying tree limbs, with chain saw on a ladder. Removed 30 or so pavers off our patio project to let them dry and set up for mortar. Drove to the local store to buy Wine and Cigs. Shop vac-ed the gutters. Shut off and moved the hose from the fountain re-fill. Helped wife reconfigure her smart phone. Made lunch, based on tortilla chips and tuna. Tended the garden around the house. Re-Checked the usual websites and E-mail with a glass of wine. Watched a few Youtubes on creating a space for Mason Bees. Walked and fed dog again. Sprayed Vegetation Killer on our walkways. Did a little weed eater work. Made dinner. Mortared and set the thirty pavers, as it got dark. Walked and fed the dog again, away from the areas I'd sprayed.. Drank a bit more wine, checked the usual internet again, and posted this. :)
You forgot to mention about knocking the cobwebs out of the ceiling corner.😂
/ What did you do at work today? #349
I got to spend 6 hours yesterday crawling around under a 100+ year old building looking for water valve shutoffs in a dirt crawlspace. All was fine until my way out. About 50' from the end I ran my left shoulder into a piece of unistrut and it took me to the ground. OUCH! :LOL:
Customer needs the holes clocked differently.
/ What did you do at work today? #354
Fixing leaks in a tower from last weeks freeze
/ What did you do at work today? #356
Built a set of telescoping stabilizers for a Deere 3032E, put a new seat on my Steiner (I work at home), and worked on an adjustable strut for a Ventrac blade.
/ What did you do at work today? #357
8 hours of this, 12 hours start to finish. Typical day.
View attachment 848831View attachment 848833View attachment 848834
As a ten year old flying to see the grandparents on Pan Am the captain invited me to the cockpit and I had never seen anything like it... mesmerized by it all.
Maybe we did live in the golden age...
I was so enamored my dad called the tower at the Oakland Airport and I was invited to visit the tower...
In the Navy dad had experience as a flight controller... Jacksonville Florida... don't know if that factored or not.
/ What did you do at work today? #358
I spent a full 9 hour day explaining to people, who were just trying to have an enjoyable day outdoors on a snow covered mountain, that ice, and freezing rain can overpower the best "lift access" machinery man can make.
It will be better tomorrow, "but check the web page for status". ;-)
While also covering in the event of any injury or medical emergency that may occur in a population of several thousand.
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59910)
2018 FREIGHTLINER...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60352)
2019 International...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Dvorak Model 3072A Hydraulic Ironworker S/A Towable Trailer (A59228)
Dvorak Model 3072A...
John Deere 8310R Tractor (A64047)
John Deere 8310R...
2018 KENWORTH T680 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2018 KENWORTH T680...
