Lawn Boy problem
/ Lawn Boy problem #1
dodge man
Super Star Member
West central Illinois
JD 2025R
Ive got a Lawn Boy two stroke that doesn’t start well. It’s a little over 20 years old. I installed a new carburetor last year and put a new primer bulb on it several years ago. I suspect something is wrong with the priming system. If I shoot a little low pressure air in the hole in the primer bulb it starts normal. If I just pump the primer bulb it won’t start. The choke closes correctly, it’s a manual choke part of the throttle. Ive looked at the exhaust port it seems clear. I’ve tried a new spark plug. It doesn’t get used a lot, just for trimming but it’s an aluminum deck and is a nice mower. It starts fine after it’s warm and runs well. Any ideas?
/ Lawn Boy problem #2
Have you tried replacing the primer bulb? They get old and crack allowing them to leak.
/ Lawn Boy problem
Yes. In my original post I had said I replaced it. I do wonder though it never seems to spring back up immediately, I wonder if it’s a cheap aftermarket?
/ Lawn Boy problem #5
I would pull the primer hose off the carb and place in small container of gas to see if you get air movement when pushing the bulb. Since works with light air pressure points towards volume loss or inability to build any pressure.
They are a simple circuit that can be frustrating
/ Lawn Boy problem
Since it starts easy when warm and runs and makes good power I assume compression is good and not a sticking reed valve but don’t know for sure.
I also think the primer just isn’t moving enough air but don’t know why.
/ Lawn Boy problem #8
My guess is the primer bulb. I used to have one of those ---- best mower ever! Finally gave up the ghost after 25 years. Wish I still had it!
/ Lawn Boy problem #9
But you said you replaced the primer bulb "several years ago"... Did you also do it again recently? Seems likely the culprit
ETA: and replace any hoses too. Sometime they crack and it isn't obvious and it can cause problems.
/ Lawn Boy problem
I ordered a new primer build just now off of Amazon, $7. It also comes with a hose and the plastic base the bulb goes on. I looked at the hose today and it looked ok but there isn’t much else it could be. I’ll post an update when I get the parts and install them. Thanks for all the suggestions.
/ Lawn Boy problem #11
I had a cub cadet and ordered a small $10 fuel pump form
amazon and when I put the choke on turn key instant start
and make sure to reduce choke. Saves wear and tear on
the starter
willy
/ Lawn Boy problem #13
Worked on these mowers back in the early 70's. Do a vacuum test. You may have seals leaking air into the crankcase pass the crankshaft. It's a 2 stroke like a chainsaw.
/ Lawn Boy problem
Success. I ordered a new primer setup, included a new primer bulb, the base and the primer hose. What should have taken 45 minutes took more like two and a half hours. The first attempt I’m guessing the primer hose didn’t get attached well, one of the screws holding the carb on is in the way. The second attempt I took the carb off, all the linkage fell off and I had to watch a YouTube video on how it went. That failed also as I discovered a gasket laying on the mower deck after pulling the start cord 20 times.
The third attempt was a success. I had my wife help me as getting the carb on with two gaskets and a metal plate (heat shield) in between the carb and engine is like trying to push a rope. It started on the first pull. I’m still not sure what was wrong in the first place but something with the primer, it’s base or the hose. Total cost was $7.55 from Amazon.
/ Lawn Boy problem #16
All good posts. I had a lawn boy 2 stroke doing similarly. Shop said something inside like a crank seal went bad I think I remember right. I chunked it. Maybe you have better luck
/ Lawn Boy problem
It’s aluminum deck and has the power drive to the rear wheels so it’s a nice push mower.
/ Lawn Boy problem #18
I had an old seventish. No bulb on it. Crank second pull. Lawnboy isn’t what it once was
/ Lawn Boy problem #19
Lawn Boy was bought out by Toro a number of years ago. I'm not even sure they exist anymore. The 2 strokes of old on lawnboys are long gone for sure as the regs have killed them off.
White 5100 12R Planter (A66285)
White 5100 12R...
New/Unused Wolverine 72in Quick Attach Brush Cutter (A65583)
New/Unused...
New/Unused Quick Attach Backhoe Attachment (A65583)
New/Unused Quick...
2021 DITCH WITCH HX30 TOWABLE VACUUM TRAILER (A63276)
2021 DITCH WITCH...
Heavy Duty Steel Baskets (A65579)
Heavy Duty Steel...
John Deere 350 Sickle Bar Mower (A66408)
John Deere 350...
