TYM 574
/ TYM 574 #1
Williy
Elite Member
Texas
Yanmar YT 235C Yannar YRC 60 rotary cutter, Yanmar RT72 rotary tiller B75 Backhoe & bucket & thumb, LS land grader
Anyone with a TYM 574 tractor should view this as the shift stick or something is
common problem that is known by TYM
willy
/ TYM 574 #3
PTO switch being bad... Uncommon, but probably an easy and logical place to look.
The gear shift lever. Maybe there is a design issue. He is blessed to have a dealer that would send him parts to do a warranty repair on his own. That's not common, for this reason, HE INSTALLED THE LEVER INCORRECTLY. Then he blames it on a yet unknown mechanical issue. My guess is, he indexed the lever incorrectly. He indexed it to neutral, the neutral switch then indicated neutral, but it was actually in LOW. Simple process of indexing the lever correctly I'd presume, which the dealer would have done, if they weren't so kind as to send him the parts to install himself incorrectly.
I'm sorry you are making payments on a tractor that was broken... But guess what, some people pay cash and have $30k in that broken unit, not a measly down payment. Cry me a river. New tractor owner indeed.
/ TYM 574
Here is another heads up so you can check your tractor and
not have the problem
willy
/ TYM 574 #6
Actually had a pitch trim run away in one of our aircraft due to a similar issue. A fastener in the control column rubbed away the insulation on a wire and shorted the pitch trim switch. The Branson legacy models have a different ignition location, so this shouldn’t be an issue on the /20 series TYMs
21ft Gooseneck Hay/Pine Straw Trailer (A65563)
21ft Gooseneck...
Rogator RG1300C (A63689)
Rogator RG1300C...
2020 VOLVO EC200EL EXCAVATOR (A65053)
2020 VOLVO EC200EL...
CAT 215CLC Excavator (A66285)
CAT 215CLC...
2016 PETEBILT 579 69 SLEEPER (A62613)
2016 PETEBILT 579...
John Deere 5420 Tractor with Quicke Loader (A64047)
John Deere 5420...
