Gas/Oil Mixture
/ Gas/Oil Mixture #1
NibbanaFarm
New England
BCS 739, Cub Cadet 2544
What are people running as their gas/oil mixture ratio in small two stroke engines?
When I was a kid back in the 1970's I used to mow a lot of neighborhood lawns. My dad bought me a Lawn Boy commercial mower. It was a 22" push mower with steel, ball bearing wheels and a cast aluminum deck. One gallon gas tank. Industrial two stroke engine. No frills, just built to last. We used 20:1 gas:motor oil. Some guys mixed 18:1. I mowed a lot of lawns with that thing and never had a problem. My dad was still using that mower in 2000 and beyond.
Nibbana
/ Gas/Oil Mixture #2
I usually go about 45-1 on everything. It makes me feel a little better than going 50-1. I’ve never had a problem and I have a lot of two stroke equipment.
/ Gas/Oil Mixture #3
I mix mine 50-1 like they say to do. I realize that’s probably largely due to emissions but I’ve done that for hundreds of gallons of mix and never had a failure.
/ Gas/Oil Mixture #5
50:1 with echo red armour. 90 octane ethanol free gasoline. Use same mix in all 2 strokes
/ Gas/Oil Mixture #6
I use 50:1 with high quality synthetic oil. Not Red Armor but I'll probably switch to that when I'm done with the stuff I have. The old 20:1 ratios were because the oil was poor. Chainsaws are low power industrial engines. They don't need a lot of oil like a highly tuned motorcycle race engine.
Also, the operator is breathing the exhaust which contains tiny droplets of unburnt oil. That's not good for you. Less of it is better.
/ Gas/Oil Mixture #7
I follow the manufacturer's recommendations... for chainsaws 50:1. Hopefully they know what they are doing.
Somebody on this site has explained that too much oil will lean out the engine. I don't understand why, but it made sense when I read it.
/ Gas/Oil Mixture #8
50:1 and mix 5 gallons a year with good 2 cycle oil for chain saws, Stihl blowers and Tanaka trimmer a gallon at a time to keep it fresh. Used to do 40:1 but 50:1 starts easier and runs cleaner.
/ Gas/Oil Mixture #9
My dad run his chainsaw at 40:1, I run mine at 50:1 most of the time, that’s the manufactures recommendation but often i put a bit less gas in it so might be 47:1 just for safe measure.
/ Gas/Oil Mixture #10
Oils have changed over the years also. So a Lawn Mower, Air Cooler, Hot Running, Small Engine, I would run a little Heavier than 50:1, maybe 40:1 or so. But Air Cooled Oil, not Outboard Oil that burns off at lower temps
/ Gas/Oil Mixture #11
interesting, i always wonder what was the difference with outboard mix oil … let’s say if someone is in a pickle and only has that just mix it richer in oil ?
/ Gas/Oil Mixture #12
The difference between a 50:1 and a 40:1 mix is negligeble. But lets break it down by oz of fuel mixture. An oz of 50:1 contains .0199 oz of oil and .9801 oz of gas based on a 128+2.6 oz complete mix. An oz of 40:1 contains .0243 oz of oil and .9757 oz of gas based on a 128+3.2 complete mix
So a carb that is calibrated for 50:1 will be set for .9801/.0199 mixture but if you use 40:1 the engine will only be receiving a .9757/.0243 mixture. So the lower amount of metered gas per engine cycle will result in a leaner fuel mixture.
As a side note the older Poulan Pro saws ran a 40:1 but the new saws are 50:1 so to compensate Poulan has come out with their own version of a premix gas like everybody is selling now. So how do you explain a multi-mix gas such as
But the can says for use in 40:1 products. So it sounds like Poulan is recommending the use of a 40:1 mix in their 50:1 products.
/ Gas/Oil Mixture #13
what is the carb calibration ? isn’t none electronic carb calibration only air vs fuel ration more oil in fuel = more oil in engin.
nvm it’s late … more oil in fuel = less fuel with the same amount of air = leaner … to run richer in oil/gas ration one would also need to adjust the carb air / gas ration.
/ Gas/Oil Mixture #14
Been using 50-1 since the 70’s in every 2 stroke engine I ever owned. Seems kind of amusing when folks claim that the manufacturer recommendation's of 50-1 isn’t enough and will ruin the engine.
/ Gas/Oil Mixture #15
I run everything on Efree 89 and 40:1. Use JASO FD rated oil IMHO.
VPracing oil.
It's my equipment and my choice.
I wont run EPA ratio's they want you to run or what dealers been told to tell you to run. They dont care they are in the market to sell you more ope.
/ Gas/Oil Mixture
I have to tune all of mine occasionally. Husq chainsaw and hedge cutter, and Echo trimmer. I tune them by ear. I don't recall ever having to tune that old Lawn Boy mower though. All I remember ever doing to it was cleaning the air cleaner and reoiling it.
2019 FORD F-250 SUPER DUTY (A65643)
2019 FORD F-250...
New/Unused Quick Attach Backhoe Attachment (A65583)
New/Unused Quick...
2013 Ford Transit Connect Cargo Van (A61573)
2013 Ford Transit...
JOST FIFTH WHEEL PLATE (A64276)
JOST FIFTH WHEEL...
ASSORTED STIHL POLE SAW PARTS (A62613)
ASSORTED STIHL...
2001 THOMAS-INTERNATIONAL 3800 SCHOOL BUS (A62130)
2001...
