Can you guys help me select the right snow removal implement for my specific application ?
   / Can you guys help me select the right snow removal implement for my specific application ? #11
What do others in your area use. Consider those options.
   / Can you guys help me select the right snow removal implement for my specific application ? #12
Obviuos solution.
   / Can you guys help me select the right snow removal implement for my specific application ? #13
Is it that obvious ? ops own a tractor, the expensive tractor plow model is $5,000... a boss V plow is $7,000 at the low end plus installation, we don't know if OP own a truck and a truck capable to accommodate a V plow, plow on truck put lots of stress on the front end adding on the wear and tear plus are annoying to drive around as a daily vehicle (if the case) and the other alternative is removing after each used (also annoying) while his tractor stay sitting doing nothing. Then there is a lot more controls, visibility and traction on a tractor.... I don't see it as obvious option unless I am missing something.
   / Can you guys help me select the right snow removal implement for my specific application ? #14
No matter what you "scrape" your driveway with, there will be some marking. If you don't get a lot of snow, perhaps a sweeper would work:
The one above is no longer available but there are many on the market
I see them used around here and they work well for all but the deepest snowfalls.
   / Can you guys help me select the right snow removal implement for my specific application ? #15
I would suggest an 8 foot 3 point backblade. At a 35° angle the 8 foot blade will be wider than the width of your tractor.
UHWM cutting edge or a horse stall mat under your cutting edge that the blade basically floats on. Either works very well and will save scaring the pavement.
Nice size Juniper trees in your photo!
   / Can you guys help me select the right snow removal implement for my specific application ? #16
If it is an option for your tractor I have been very happy with my front mounted snowblower I do 4 driveways ( my neighbors ) in 1.5 hours and very little damage and a 32HP tractor.
Angle blade all the way, in your case you could get away with manual adjustment if you are willing and capable to get on and off your tractor, once you get the hang of it you should only have to adjust it once. I also see the ouch beside #3 yet I see your driveway and your house and that's what I say, if you go for the manual one and slip and fall what will you say ? when you sell that implement you will get most of that money back. A quality item hold value more then a cheaper implement and experience less wear and tear. Do you used your box blade during the winter? I have seen guys utilizing it for dead end spot to pull snow away from entrances. Depending on the amount of snow, and wind in your area I would consider a front end snow blower, having no snow bank and opening your driveway in two pass is a wonderful thing but as your comment '' I would only used it a couple of times'' sound like a snow blower wouldn't be worth the expense.
nice place 👌
Thank you, this confirms what I was already leaning toward.
I've cleared my property with ATV + angled blade for the past 10 years and have gotten to grips with that angled blade. Due to the nature of my driveway and some of the parking spaces, there's just moments where I need to convert it from angled to straight push and vice versa. Another area where I would go for a straight push is where my driveway tapers out and hits the street. That is where the third function and hydraulics would serve me well. On top of that, I'll be inside my heated cab, no need to get out of that environment :)
I'm going to reach out to one of the dealerships and check how long it would take to get the IronCraft. They're US made and rather sturdy (got their flail mower).
   / Can you guys help me select the right snow removal implement for my specific application ? #18
Looking at the photos provided ... I would guess the solution will become more obvious after a couple more decades screwing around with the "toys" and getting the windburn..
Age tends to bring wisdom ........ in most cases.
Looking at the photos provided ... I would guess the solution will become more obviuos after a couple more decades screwing around with the "toys" and getting the windburn..
This was my second home until 2 years ago. My winter visits were just limited to 2 weeks around Christmas, which is a different situation from living here all winter :)
   / Can you guys help me select the right snow removal implement for my specific application ? #20
If I had that property, I would NOT buy either option the OP offered. The snow pusher would fill up and you would have to drive off the pavement to dump. The v-plow is fine except the one the OP listed is not a floating design. The only option is to float the FEL which is not optimal. There are designs that are floating so the weight of the loader arms stay on the front tires, where it should be.
(APPROX. 25) 4' X 8' X 3/4" OSB SHEETS (A52706)
(APPROX. 25) 4' X...
2018 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A58017)
2018 INTERNATIONAL...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
2024 Spartan SRT-XD Zero Turn Mower (A59814)
2024 Spartan...
2012 JACK COUNTY TANK 130 BBL STEEL (A58214)
2012 JACK COUNTY...
Kubota M4700 4WD 51HP Utility Loader Tractor (A56857)
Kubota M4700 4WD...
