CH4Ohio
I don’t do a lot of woodworking… just small things around the house…
Right now the plan is to see what’s possible with my circular saw/demolition saw/jig saw… lots of good ideas available for: “do i really need a table saw”?
I get it. There are lots of easy fence options that will work for ripping with a circular saw. Just be sure to make yourself a stable wide surface to work on so you're not trying to "balance" your saw on a skinnier board.
I use a compound sliding miter saw for most all crosscuts these days. Circular saw for occasional ripping and panel cuts. (Just because it's quicker than clearing my mess off the table saw.)
Another common mistake is NOT adjusting the depth of cut. You only want an 1/8" - 1/4" of blade clearing the cut on the back side. Lots of people will use the same setting whether they're cutting a 2x8 or 1/4" lauan. All that extra blade dragging through the cut really slows the motor down and causes the blade to grab and kick-back.
) Doctors asked why I pulled it out? Just a reaction. All they could do was sew up the eyelid, sent me home with an eyepatch and pain meds. The screwdriver went through lid at top, rolling eyeball back.
