Oil & Fuel L2502 smokes really bad at cold start
   / L2502 smokes really bad at cold start #21
Does your tractor smoke like that? I don't think power service will help but you can try..
   / L2502 smokes really bad at cold start #22
Personally I wonder if it is the dealer or if there isn’t a bit of “buyers remorse” going on here
If you end up finding enough wrong with it, you will get all your money back and the dealer will owe you money!
I wish I never found anything wrong with it but it seems like this thing was made on Friday.
   / L2502 smokes really bad at cold start #27
I would send it back to the dealer..
   / L2502 smokes really bad at cold start #28
If you get on and goose it, increase the rpm and run the rpm up and down some after the first 20 or 30 seconds does it still act that way or does it "clear it's throat?"
   / L2502 smokes really bad at cold start #29
Is yours an L2502 or l2501. 25 hp?
No, it is an earlier Kubota from an era with similar injection and emissions equipment to the 25 hp tractors made after 2014 and the introduction of the Tier IV emissions requirements in place now.
1643 (A58375)
1643 (A58375)
2000 Ford F-650 Truck, VIN # 3FDNF6541YMA65799 (A57453)
2000 Ford F-650...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2019 INTERNATIONAL DURASTAR 4300 REEFER BOX TRUCK (A58214)
2019 INTERNATIONAL...
2017 Hino 155 16ft. Box Truck (A56858)
2017 Hino 155...
3" X 4" GAS POWERED WATER PUMP (A52708)
3" X 4" GAS...
