fuel filter schedule
/ fuel filter schedule #1
WinterDeere
Super Star Member
Rural 'burbs, north of Philly
John Deere 3033R, 855 MFWD, 757 ZTrak; IH Cub Cadet 123
Deere 3033R (33 hp Yanmar 3-cyl diesel) wears two enormous fuel filters, to the tune of $80 for a full change, which is recommended at 400 hours. If seeing less than 400 hours per year, then they are to be changed yearly.
But given the cost, mess, and wear and tear on disassembling the clear plastic separator into which one of the filters is assembled, I'm wondering if that's really the smart plan. The filters always look clean after a year, and there is zero visible water in the separator. There is a drain cock on the bottom of the separator, so even if there were water, it could be drained without touching the filter.
Does it make sense to just wait for 400 hours, even if that's only once every 4th year, if there's no visible water or dirt in the separator? Or split the difference at 2 years and 200 hours?
/ fuel filter schedule #2
What is it filtering out?
Is it under warranty?
It's your $$$ but if it is not under warrantee I would just buy a set of filters now and run it to the 400 hour mark, have the oil tested, then decide.
/ fuel filter schedule #3
I would wait till 400 hours. I don't remember the last time I changed my fuel filters. My fuel is filtered 2x before it gets to the tractors....
/ fuel filter schedule #4
If you’re not using it much I’d actually recommend changing more often. The crap that grows/accumulates in diesel stored for a while is really hard on injectors. Running often 400 hrs is plenty often.
/ fuel filter schedule #5
If you want to really know the status of a fuel filter, install a vacuum gauge. I added a vacuum gauge to the Racor filter on my tractor, and it generally starts out at 1.5 - 2.0 inches of Mercury (I think that is the scale used). At 10" Hg it's time to replace the filter.
/ fuel filter schedule #6
use a good diesel additive/stabilizer & purchase diesel from a high volume reputable dealer.
maybe mr funnel or similar when fueling. those alone will extend fuel filter interval change
as you mentioned, good to keep an eye on the separator.
/ fuel filter schedule #7
I have a JD 2025r and just changed the main filter at 400 hours. It had a little more crap in it than I expected. Looking through the bowl it looked pretty clean but once I took it off the tractor it was obviously a little dirty. Mostly small pieces of dirt. My tractor is almost 5 years old. I’m not sure every year is needed but more often than 5 years.
Not sure. Dirt / sediment, I assume. But I also believe algae/bloom is more likely to cause problems than dirt, in filters installed for several years.
Dunno. It was purchased new in 2019, but I don't remember the warranty terms on each item.
Fuel filters, not oil filters.
Just curious... how is it filtered 2x before it gets to the tractors? Mine is filtered 2x between fuel tank and engine, as described in OP, but I don't do any external filtering before pouring into the tank.
I average 110 hours per year, but that could be 70 hours one year and 150 hours the next. Either way, 400 hours is 4 years for me.
Now that's an answer any engineer can love. I'll have to look at the arrangement of pumps and filters, and see where it's appropriate to tee a gauge into the line. As noted, there are two filters, and one of them has three lines going in/out of the filter base. It sounds like your setup may have all filtration before the first pump, but I suspect mine has an integral bypass, probably with the first stage fuel pump between the two filter stages.
/ fuel filter schedule #9
Mine has the primary sediment bowl filter, electric lift pump, to the secondary OEM spin on filter. A vacuum gauge could be tee'd immediately after the filter and before the lift pump. The Racor has a port for the gauge on the filter housing.
I filter my fuel from a transfer tank with a 17u water separating bowl, followed by a 2u finishing filter. The primary Racor on the tractor is currently 2u, which is not ideal in the primary position. I figure that since I'm filtering the fuel going in the tank down to 2u I'll be ok. So far after maybe 200 hours it's working well.
/ fuel filter schedule #10
I have a filter on my transfer tank that's in my pickup. Then a filter on the 275g bulk tank.
My transfer tank is a 5-gallon gas can. The only diesel I presently own is a 33 hp tractor, and even that is operating near idle RPM most of the time. I'd guess I use less than 50 gallons of diesel per year!
Gasoline... different story. My vehicles and mower are all much more thirsty machines, than the tractor.
/ fuel filter schedule #12
We seem to dance to the same drummer on fuel filtering but I don't have a vacuum gage (probably should have however). I just observe the clear bowl on the bottom of the Racor and drain accordingly. I have not changed the OEM filter(s) since I installed the Racor. No need to. The Racor filters down to 5 microns which is well below what the OEM filters are at (15 microns). Best money I ever spent. In fact (again), all new common rail ECM controlled Kubota's are coming from the factory with a Racor clone now. Says Kubota on the element but it sure looks like a Racor to me, right down to the clear spin on bowl and I believe Kubota offers the 12 volt mullion heat plug as well. One advantage to the clear bottom bowl is, if your fuel is gelling, you can see that instantly, unlike the somewhat opaque housing that contains the secondary filter and water ring that you cannot see easily. Up here, gelling is always an issue in the winter without using some sort of additive. Myself, I use Power Service winter additive. The cloud point on ULSD isn't that far below 32 degrees.
/ fuel filter schedule #13
The mere fact that you are asking the question puts you way ahead of many operators!
You are careful about fuel handling and freshness.
I would think the 400 hour interval will be fine!
Good Luck!
Good Luck!
Thanks. It's been 115 hours since it was replaced this time last year. I think based on all the feedback here, I will skip it this year, and re-evaluate next year. The separator bowl is clear plastic, and I see no water or debris in there, so I think we're safe. Even if I do it just every second year, that's still saving me time and money, and more importantly wear and tear on all of those components getting disassembled and reassembled every year.
/ fuel filter schedule #15
The fuel filter in my truck hasn't been changed in over 100k+ and
no problems. I would change it if I was having problems
willy
willy
I've always pretty much followed recommended maintenance schedules on all my machines. I have a huge spreadsheet that tracks every maintenance item on every machine, and each year at this time I use that to tell me what's due and what filters and fluids to buy.
Fuel filters are marked as "yearly" in pretty much every manual for every machine I own, so I must replace more than a half dozen per year. Most are cheap little $1 inline 1/4" barb things, so I never really gave it much thought, but the pair of OEM fuel filters for the 3033R are $80.
But to your point, I can't even remember the last time I changed any fuel filter in any on-road vehicle.
/ fuel filter schedule #18
I live in a dry climate. Algae doesn't seem to be a issue. I believe I had over 1000 hours on mine before I changed it. If I didn't live in a dry climate I think it would be a different story.
/ fuel filter schedule #19
My two Kubota's fuel filters last much longer after I bought a 50 gallon cube with a 10 micron filter on it.
It's sold now, but I had to change the fuel filter on my 1997 Dodge diesel at about 12k miles. One time a screwed up and didn't change it until 20k and the filter was so dirty it was collapsing.
/ fuel filter schedule #20
Exactly. It all depends on your fuel. I buy diesel at the same place we fill our cars - and probably pay a premium for the privilege. Use dedicated 5 gallon containers, so I can see inside and I don't use the dregs. Pour it through a filter into the tractor. And I use a winter anti-gel additive year round.
I don't remember the last time I changed fuel filters in the Kubota.... ten years ago at least. Filter looks clear and clean.
When we bought our construction machine - a JD310 with 6000 hours - it required several filter changes and draining the bottom of the fuel tank before it would run reliably. Luckily, on commercial equipment changing the fuel filter is quicker, easier, and cheaper than on homeowner tractors. And the fuel tank has a bottom drain specifically for cleaning dirt and water out of the tank.
2014 Toyota Tacoma Ranch Camper Shell (A64126)
2014 Toyota Tacoma...
2012 JACK CO 130BBL VACUUM TRAILER (A67714)
2012 JACK CO...
CATERPILLAR ENGINE (A67714)
CATERPILLAR ENGINE...
2017 JLG G5- 18A TELEHANDLER (A59914)
2017 JLG G5- 18A...
2016 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A64279)
2016 CATERPILLAR...
2014 Chevrolet Impala Sedan (A66738)
2014 Chevrolet...
