Rotary cutter gear box to PTO connection
   / Rotary cutter gear box to PTO connection #1
RX7320inEastTN
Want to own Kioti RX7320. Have owned 45hp New Holland and 60hp Solis.
I have a 6 foot Tennessee River Implements rotary cutter (NEW), and I need help connecting PTO to gear box splined shaft. PTO shaft not connected when I purchased the rotary cutter. Rotary cutter has a 90hp gear box with splined shaft. PTO portion has a nut that is visible, screwed on to a threaded "pin" or bolt. But, IF it is a bolt, it does NOT have a bolt head. There is a hole in the splined shaft that protrudes from the front of the gear box, but it does not look like a big enough hole to handle the "bolt" on the PTO side of the connection. I called the place I bought it from, and hopefully they will call me tomorrow. But thought I'd ask here also. Thank you.
   / Rotary cutter gear box to PTO connection #2
Do you have a slip clutch on the PTO shaft? If you have a splined PTO shaft at both ends and no clutch, you are asking to break something when the cutter hits an immobile object.
I thought I mentioned it has a slip clutch, but I re-read my post and realized I did not write that. Yes, it has a slip clutch. I had this exact same model brush hog on my last tractor, and I had to replace clutch plates.
   / Rotary cutter gear box to PTO connection #4
If it's like my rotary cutter with a slip clutch, the "bolt" is really a tapered pin that's threaded at one end. The hole it goes in is also tapered, larger on one side than the other. One side has a flat around the hole which is where the nut and washer seat. The pin mates with a groove milled on the gearbox end of the slip clutch. It's a bit tricky to line it all up while working in the safety guard but it's not too hard. I use a long screwdriver that's smaller than the holes to get it lined up.
Mine came with a manual that shows all the parts. If you don't have that you can look up the slip clutch manufacturer and find the manual on their web site.
   / Rotary cutter gear box to PTO connection #5
If you go through a number of clutch discs you may want to adjust the clutch pressure. I take one of those point and shoot thermometers and just take the clutch's temperature every now and then. If it gets hot when you really load it down, but runs cool in "normal" load you might be about right with the adjustment. You want to on occasions make it slip just to be sure it is not "locked" in the engaged position. Especially if it gets wet and rusts at all.
Thank you. It came to me in my sleep last night. Remove that nut that I see on what you describe as tapered pin. Then it will go back in to that milled slot on the gear box side. I'll report back when task complete.
   / Rotary cutter gear box to PTO connection #8
@repete is right about checking the clutch adjustment while you're there. My dealer did a good job of prepping the tractor but the clutch came adjusted too tight. If it's too tight it won't slip when needed, like when you pull a large rock up out of the ground with the mower.
The manual should give you a starting point for the adjustment.
Thank you. I will do that today.
2012 CATERPILLAR 304E CR EXCAVATOR (A51242)
2012 CATERPILLAR...
2004 HYUNDAI V12530152-AJS 53FT DRY VAN TRAILER (A51222)
2004 HYUNDAI...
2005 JOHN DEERE 5205 TRACTOR (A51222)
2005 JOHN DEERE...
2021 CATERPILLAR 299D3 SKID STEER (A51242)
2021 CATERPILLAR...
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
2014 International Durastar 4300 Terex BT2047 47ft Crane Truck (A50323)
2014 International...
