Jd 4600 fuel (FIXED)
/ Jd 4600 fuel (FIXED) #1
Epoxe
Mahindra 1635 HST
4600 compact tractor. Sputters out. Won't start. Seems fuel starved. I replace the fuel filter (was nasty as heck). Fill filter bowl with clean diesel. Tractor starts, runs for 30 seconds, sputters and stalls. I check the fuel line going to the fuel lift(supply) pump, get good flow from tank. I disconnect the other hose on the lift pump that feeds the filter and try to crank it, I get no fuel from the pump. At this point I decide bad lift pump, am I missing anything before I order one? How likely is it that a mechanically driven fuel pump failed?
Thanks.
Rob
/ Jd 4600 fuel (FIXED) #2
Some filter / sediment bowls have a small screen in them. If your filter was really gunked up, I would look hard at the sediment bowl valve and (possible) screen.
On edit... I didn't read carefully enough. If you have no flow from the lift pump to the filter intake, I think the fuel pump would be suspect.
/ Jd 4600 fuel (FIXED) #3
Are you able to disassemble the lift pump? Could have pulled in some debris from the tank
/ Jd 4600 fuel (FIXED) #4
Your gonna remove it anyway, so check the screens in the lift pump..
If it comes apart, disassemble it and clean any screens in it..
And if all that looks ok,
THEN order one..
Good luck
/ Jd 4600 fuel (FIXED) #6
The lift pump runs off the cam shaft.. u won’t get any fuel from it unless the pump cam shaft is turning..
/ Jd 4600 fuel (FIXED) #7
The thermistor: Controls amperage to the injection pump solenoid.
lots of net information.
/ Jd 4600 fuel (FIXED) #8
If the fuel pump is not making contact with the cam you can always
disassemble it and put it in a forge and shape it so it will make contact
willy
/ Jd 4600 fuel (FIXED) #9
Very common if you have junk in the fuel. Pull the pump and make a scratch mark down the side so you can put it back together right, disassemble and clean. If you find something damaged, replace the pump, they are not that much.
Thanks folks. Been awful busy, just ordered the pump. I'll let yall know how it goes.
Cam shaft should be turning when I crank the motor though..
2013 Komatsu PC360 Excavator (A60352)
2013 Komatsu PC360...
1996 FRUEHAUF 45' SLIDING AXLE FLATBED TRAILER (A59911)
1996 FRUEHAUF 45'...
2015 CHEVROLET 2500 HD CREW CAB FLATBED TRUCK (A62130)
2015 CHEVROLET...
1992 John Deere 210C 58HP Loader Utility Tractor with Box Blade (A61572)
1992 John Deere...
Case 1083 20ft Corn Head (A63118)
Case 1083 20ft...
KBH Tender Trailer (A63688)
KBH Tender Trailer...
