Farm pro
/ Farm pro #1
Chancellor
Farm pro2420
I have a new project tractor that I have hit a brick wall on have a farm pro 2040 getting fuel to the injector pump in from the injector pump. A little bit of fuel is going to injector one, but getting no fuel to injector to. I am at a brick wall and would like some advice. I have checked fuel lines, gravity, flows, good.
/ Farm pro #4
Does your fuel injection pump have a cover plate on the side? Does it look similar to this?
/ Farm pro #7
No, I have the OEM injector pump that does not have the side plate
In that case you have three options:
1) Send the injection pump to a local diesel shop, or thepumpguysc.
2) Purchase a new injection pump.
3) Attempt to repair it yourself. It should be noted here that individual parts are not available, and there is no service manual for the injection pump.
Good luck, let us know what you decide.
/ Farm pro #8
Hello,
I have a Farm Pro 2010 and Someone played with the diesel pump and it has some timing issue since then. I don't think is the timing in the diesel pump is in the engine the valves. Can someone help me?
Thank you
/ Farm pro #11
Ahh.. I see now..
I’ve personally never timed one but have seen similar pumps timed in the same fashion..
If u look at the mounting bolts.. u should be able to see where the 3 bolts were tightened up on the pump mounting flange..??
Hopefully he didn’t go thru the front of the engine to “time it”..
Can I ask why he was adjusting it in the first place.?
/ Farm pro #12
Hello,
Thank you
What are you saying?
2022 EZ-GO ELITE...
Deutz F3L912 3-Cylinder Air-Cooled Diesel Engine - 48 HP - Industrial Pump Takeout (A63689)
Deutz F3L912...
2003 Ford F-550 Pickup Truck (A66408)
2003 Ford F-550...
2018 FORD F-350 SUPER DUTY (A65643)
2018 FORD F-350...
213063 (A64276)
213063 (A64276)
Big Tex 16TL20 20' Tilt Trailer (A64127)
Big Tex 16TL20 20'...
