Temp Gauge and Sender.
/ Temp Gauge and Sender. #1
JNyz
4.5 liter
Looking for help.
I have a 4.5 liter JD diesel.
Temp gauge was reading 240 but hoses were warm to touch and thermal gun was reading 120 top of radiator and 75 bottom of rad.
No temps over 120 after 30 minutes of running taken at different parts of the engine.
I decided to change the sender and gauge. Gauge only moved to 100 after 15 minutes. I popped wire off sender and grounded it out and gauge moved to hot.
I reinstalled old gauge and it did not move. I then reinstalled new gauge and if also didnt move. When grounded it out it did not move. So right now I have no temp gauge.
Stumped.
Thank you
No, didn’t see it. It an OBD leaf vacuum.
/ Temp Gauge and Sender. #4
Manual never helped me. You’re got it nailed. Sending unit, temp gauge panel or the wires between.
/ Temp Gauge and Sender. #5
Are you using OEM JD parts?
Make sure you actually shoot the temp sending unit and head/block with your heat gun. The thermostat could make the radiator appear cooler than the rest of the engine.
I put a new sender and gauge in and now gauge doesn’t work. Is there a way to test?
Can I run a wire from sender directly to gauge or does it need to go through computer?
Oh, can I text wire for conductivity?
Thanks
Not sure if OEM. I ordered from equipment manufacturer. They didn’t come in a box, came loose wrapped.
I did call a JD distributor but they said it’s proprietary I believe.
Only ran it for 15 minutes today and shot top of block and head, average around 120 degrees.
/ Temp Gauge and Sender. #8
Often there will be a voltage regulator supplying the voltage to the gauge then the wire from the gauge to the sender. The sender is usually just a varying resistance changing with the temperature at the bulb end.
/ Temp Gauge and Sender. #9
Thanks
I don’t think new ones work like the old vintage. But it must be what’s between. Or maybe you bought new bad one
/ Temp Gauge and Sender. #10
Looking for help.
Stumped.
Thank you
Have you checked to see that the thermostat is working? This sounds like a thermostat that is always open.
2013 Hitachi ZX160LC-5N Hydraulic Excavator (A66734)
2013 Hitachi...
PALLET OF CUT-OFF VALVES (A67714)
PALLET OF CUT-OFF...
2012 FORD F150 REGULAR CAB PICKUP TRUCK (A66091)
2012 FORD F150...
CATERPILLAR PC306 PLANER (A65053)
CATERPILLAR PC306...
2006 Stephens Aluminum 407 T/A Chemical Tanker Trailer (A68183)
2006 Stephens...
2009 Chevrolet Tahoe SUV (A66738)
2009 Chevrolet...
