Good morning!!!!
   / Good morning!!!! #181,831
Second picture from same area
Do you need to speak Portuguese to talk to the locals?
The types of trees/plants gives another hint, though hard to see, they reminded me of a place I have been. Not been to this place though.
   / Good morning!!!! #181,833
Good Morning! Another beautiful day forecasted, it's warming back up. 44º - 77º today. Will start discing a small section of the neighbors field. Squirrels have dug big pits on the hillsides in the steepest section. I'll try to straighten it out before it's time to drag a mower through there next summer.
Hope you all have a great day.
Curious as to your discing the squirrel damage. Is this more a surface treatment or total rework of area?
I have several areas I mow that the farmers left in shallow furrows, so mowing is somewhat a roller coaster ride in places. I had a disc harrow and have wondered if I could smooth it out. No experience discing. I prefer not to have to take it to bare ground, but don’t know if possible to just get surface smell like, even with multiple passes.
   / Good morning!!!! #181,834
snow flurries, just a few...here also
I'm guessing that fluted gizmo is a food grinder of some sort, fits into a bigger piece
or.....a very interesting pie crust maker, or a dough roller...
I remember a wooden one years ago, the other piece was a metal, mesh cone.
   / Good morning!!!! #181,835
Some of the dens are multi hole pits, the biggest measuring 3x5 ft. Most are 2 x2 and 1.5 ft deep. Many have a 1ft+ mound next to the hole... this area was disced last summer and is beginning to grow back. I didn't want to disc again but walking it yesterday I realize there are dozens of these burrows. And being in a hilly area they are a stability hazard.
My plan is to set the disc no deeper than needed and possibly disc in 2 different directions. If I need to smooth afterwards I can drag something over it. But this will reduce it all to dirt which I'm okay with. Stuff will grow back.
   / Good morning!!!! #181,836
We had sandwich for brunch. It is made by toasting full grain sourdough bread in olive oil on cast iron pan. It is made with layers of Provolone cheese, pepperoni, and more provolone, one avocado and Louisiana spice and red onions
Made my mouth water
   / Good morning!!!! #181,838
David, don't know if this helps but a simple scanner for my van will tell if it has a code but will not tell me about what may have caused a "near Code" that resulted in going into limp mode. You may have to get a better scanner to do that? Also I can generally reset the limp mode by turning off the engine and restart
Good idea, Frits
Have to research and find if a reasonably priced scanner available for my tractor.
   / Good morning!!!! #181,839
Thanks. I guess mine are maybe 6 inches at most.
   / Good morning!!!! #181,840
Good Afternoon LouNy,
I see a sign on route 22 on the north side of Hoosick, Vadnais Fuel, advertising propane for $1.60 per gal !!
You might look into that if your not going to do coal any longer !
Electric tri scooter irgc40 (A56859)
Electric tri...
2018 Caterpillar 308E2 CR Midi Excavator (A55973)
2018 Caterpillar...
Trailmobile Van Trailer (A56435)
Trailmobile Van...
Hays LT-1 Tender (A56435)
Hays LT-1 Tender...
2015 GENIE S-60 MANLIFT (A58216)
2015 GENIE S-60...
LOT OF TIN (A58374)
LOT OF TIN (A58374)
