So, first, this type of pipe is absolutely normal, for anything 4" and above, and I've seen it used in 2" before. It lasts just fine, but, I'm assuming near a change in direction, or an improperly homed joint, it has separated, and either wasn't homed, or needed a bell joint restraint or thrust block.
Me personally, I'd get a trench shovel and post hole diggers and just start spotting it every 250 ft. Maybe install a valve every 500 ft or so. Then you can come up with a general area, instead of 2500 lf between A and Z; maybe a 200 ft section between G and H.
I doubt it's deeper than 30-36" and it's really not that bad to dig a small locating trench across the general running line to locate it.
Now, you've got valves installed every 500 lf, with a 4" "riser" to the valve, preferably a few inches above the ground, and in the future, you have a fixed locate every 500 lf.
For everyone saying replace; looks like $2.31/lf x 2500 lf=$6000 just in pipe. Well worth a few hours with a shovel to find and repair the leak....
Any chance they ran locate wire or tonable tape on the line when installed (imo tonable tape is pure trash from a locating prespective, and warning tape typically just tells you what type of line you just cut...)
Pipe bursting appears to be pretty darn expensive. Locally quoted as between $60 and $250 PER FOOT.That's call pipe bursting. An aircraft grade cable and very powerful winch pulls a ram through the old pipe, breaking it out as the new pipe is pulled in. I had it done on a prior residence to break out the old and failing sewer line and install a new one. It avoids having to dig up the landscaping as only a hole (somewhat large) on each end is needed. I had extensive, beautiful landscaping so this was the only way to go.
Total cost was about $9,000. I am glad I had a fixed price contract and not time and materials. Because about half way through pulling, the high strength cable snapped, stranding the whole mess about halfway inside the pipe. The hardpan in my area and the old pipe were too much for the winch and cable being used. Before it was over they had to bring in a super-duty winch from another state to finish the job. It was quoted as a 2-3 day job, but it took nearly 4 weeks.
I've had it done several times with me using my backhoe to dig a pit on both ends in preparation.That's call pipe bursting. An aircraft grade cable and very powerful winch pulls a ram through the old pipe, breaking it out as the new pipe is pulled in. I had it done on a prior residence to break out the old and failing sewer line and install a new one. It avoids having to dig up the landscaping as only a hole (somewhat large) on each end is needed. I had extensive, beautiful landscaping so this was the only way to go.
I dont know I would go every 150 feet; but every 500 ft would be a good idea. Yes, there is some Marginal reduction of flow (pretty darn marginal); but it gives you options. Looks like between $9-45/valve, depending on type/material.Helped a friend when he was building and asked why so many shut off valves and hydrants from
Meter to home?
Every 150’ he had a box with a line shutoff and a riser with a hydrant shutoff.
He said it’s 900’ and if I have a problem down the road I cans quickly isolate the location to within a 150’ plus point to point I know exactly the run.
It doesn’t freeze here so no worries about that.
It was also to have water readily available for future projects and irrigation.I dont know I would go every 150 feet; but every 500 ft would be a good idea. Yes, there is some Marginal reduction of flow (pretty darn marginal); but it gives you options. Looks like between $9-45/valve, depending on type/material.
There are several ways to locate wire buried underground. You could do a web search. Never mind, I just did one. This link is for one device but there are several similar devices: https://www.amazon.com/Underground-...nEWAT6sRPF8zWeMKB7-sRIlBxfBoCOoEQAvD_BwE&th=1All,
Thanks so much for your replies. As for why I think I have a leak are these clues: (1) we had a leak in the line before. We knew because our water usage went WAY up one month ($1,000), and there was a place visible in the pasture which was green and wet while elsewhere the pasture was still brown, (2) just this month we accidentally were given the water bill for our neighbor as well as our own. The neighbor's bill was something like $30 while ours is $200. They have 3 people in their household while we only have 2. We don't water our lawn or a garden, and only have 2 dogs and 4 chickens to water besides us humans. (3) After seeing the neighbor's water bill, I cut of all water at the house (which I installed when I had water issues before), then went to the gate to see if the water meter was turning. It was. (I took a phone video of the meter but it was too large to upload - 24 MB.) It is not turning fast but steady enough to cause our water usage to much more than needed.
Regarding locating the pipe, one thing that might help is that the old phone lines were buried next to the water line. The phone linesare being used(edit: are NOT being used), so I or someone else might could use them to send a signal that could be detected.
If I am able to locate the leak, then I will most likely try to repair it.
Thanks again for all of your replies.
Senile Texas Aggie
I wonder if you can use polypipe for a hot water line?I would use something like this.
1" x 1000' SIDR 11.5 160 PSI Excel Potable Water Poly Pipe
1" x 1000' Excel 160 PSI Flex Water Pipewww.menards.com
Did you have any luck with your waterline? I am really curious as to the outcome.All,
I reside on 160 acres in western Arkansas. My driveway (and water supply line) is about 1/2 mile long. The water line is leaking somewhere between the gate and the house but I have not found where. The water line is about 20 years old and so the seals around the PVC may be leaking. I forget the name of this type of piping, but the piping is not glued to each other. Instead a 20' section of pipe is made with a male end and a female end. There is a gasket (O-ring) in the female end that seals the male end of the next pipe. These pips are laid out and then covered over, They work great as long as the ground is not disturbed and the seals don't fail (which apparently starts to happen around 20 years).
My problem is that I don't know exactly where the water line is buried. I know where the line is about 1/4 of the way from the house, as it leaked there and was repaired back in 2020 (that was an adventure but a story for another time). The water meter is located at the gate, so that is the other end. But where the line is in between is a mystery. I see no signs of leakage in the pastures, but the water line crosses a small creek at an unknown place, so it may be leaking there. We had a really dry summer and there was no sign of water entering the creek, as it was completely dry, but maybe the trees there are absorbing the water that is leaking.
So what do you folks recommend: (1) find the leak and repair it, (2) replace the entire water line with a water line that won't use gaskets/seals that will deteriorate, (3) something else?
All recommendations are welcome. Thanks in advance.
Senile Texas Aggie
