Attachment for managing cleared woods
   / Attachment for managing cleared woods #1
snpower
Gold Member
Charlottesville, Virginia
John Deere GT235, GT 275, 1025R
Happy Holidays!
Recently I had a forestry mulching service clear much of our wooded lot. It looks fantastic! So, in order to maintain it - dig up saplings, weeds, undergrowth, etc. I am looking at a ratchet rake for my John Deere 1025R. I previously had a rear rake but never used it. Other thoughts were the rear dethatcher from Good Works. This seems less ideal but I have a BXpanded tooth bar on my bucket so between the two I might be ok, and the dethatcher would be good for fall leaf cleanup. Any thoughts?
   / Attachment for managing cleared woods #2
So, I guess the question is; what do you want it too look like? Do you want grass, and non-woody veg to take over? Are you wanting to plant grass, cover, or food plots? If so, I would disc, staying about 4 ft from the base of the trees. I know a 1025 isn't going to pull much of a disc, but the problem with a mulcher is, it doesn't do anything about the root systems, and they will quickly shoot woody stems back up. Or is it a general wood chip/leaf thing you want to clean up?
Without seeing what was there before the mulcher; I would expect a lot of regrowth come early summer, once it starts raining. (or when ever your rains start; here, springs are can be extremely dry)
If it's the leaves/wood chips that your concerned with; I'd try to rake/blow/burn
   / Attachment for managing cleared woods #3
Why not get a flail mower and mow it occasionally? It'll mulch up small branches and get the little stubble that starts popping up. Along with mulching up the leaves.
Would do much better than a brush cutter.
   / Attachment for managing cleared woods #4
I haven't looked at the Good Works Dethatcher, but typically, they aren't nearly heavy duty enough to stand up to 1 or 2" roots/stubble. Think you would destroy the attachment, unless it's build for that?
   / Attachment for managing cleared woods #6
Looks clean and no sapling stumps or rocks to hang up on - use one of your GT's and mow at the highest setting a few times a year would be easiest. Get mulching or gator blades - they will chop up the leaves and are good for the soil and remaining trees.
I have a ratchet rake and it doesn't like rough/rocky ground - the loader jumps over the difficult stuff and makes more of a mess exposing the remaining tree roots you dig up trying to remove the saplings. If you still are set on removing them, you have a tooth bar so no need to get a RR IMO.
For stumps sticking out cut them down level with old chainsaw or trimmer with brush blade.
   / Attachment for managing cleared woods #7
I'm currently having forestry mulching done. The operator recommended spraying in a couple of months to prevent regrowth and then keeping it cut. I probably won't try to rake any of the chunks left from mulching, but if I did, I'd use a rear rake. The teeth are deep enough to move a good amount of material and the spring action will help to keep anything from breaking if they happen to hang on a smaller stump or rock buried in the mulch.
Just walking over some of the area, I'm seeing pieces of locust thorns in places that I will need to pick up by hand and burn.
There are some trees and stumps I will cut with a chainsaw.
   / Attachment for managing cleared woods #8
Looks like my yard, the best and quickest option we have found is a good zero turn mower, hands down, we have 6 acres.
We did use a landscape rake to pile up a lot of the mulcher shreddings, and now just mow it.
This is one of a few mulch piles we have, and we are 2 years post mulch, things are starting to break down and a decent compost is forming. Maybe another year or 2 and it'll be great for the garden, for now, the dogs like it.
Grass is starting to fill in the areas that get enough light. As above, we've found zero turn mowing is the fastest and easiest to get around the trees. Unless you want a golf course, just mow the leaves a time or two and they'll be gone for the most part.
   / Attachment for managing cleared woods #9
Just mow it. That's all you have to do. Don't make a mountain out of a mole hill like some will have you do.
Either a brush cutter or flail mower.
Simple.
   / Attachment for managing cleared woods #10
How big is your wooded lot?
If it was me, I'd just go over it a few times each season, maybe once a month depending on regrowth, with my 3 pt brush mower set as low as it would go.
Previous poster recommending mulching blades on your GT isn't a bad idea either. Just with smaller, thinner blades, you'll probably have to mow it more frequently to stay more ahead of the regrowth.
After doing that for the first couple of seasons, it will be much easier to keep it looking nice.
183 (A52705)
183 (A52705)
2025 Yakta YXR970 Zero Turn Mower (A57453)
2025 Yakta YXR970...
(4) P275/55R20 TIRES (A58374)
(4) P275/55R20...
Workman Cart (A56857)
TANK MANIFOLD (A58216)
WICKER BENCH & WEEDEATER MOTOR (A58374)
WICKER BENCH &...
