EddieWalker
Epic Contributor
You have stuff on there that I never knew existed on tractors.   It's interesting to learn about these things, but it also makes me happy to know that I don't need all that stuff. It just sounds super expensive!!!!
			No, it doesn't work that way. When all my efforts still left the barns inefficiently packed and the tractor I wanted out was the first one I put in, I too figured more space was the answer.Really wanted to leave Magnum hooked to baler. That way it’s easier to work on baler, but it would be 50’ long, blocking access to the right & left sides of the barn.
Maybe I’ll be reincarnated as a wealthy farmer next life and will have huge tractor barns. haha
Having been there and done that, 80' x 120' or bigger with doors on three sides would be better. Concrete some or all, put foam or heat under the concrete and do a smooth finish that you can later wax with anti slip. You will never slow down in life and this will help out.U ain’t kiddin…
I have a 60’x40’ now.
Honestly, I need an 80’ x 60’ with wider doors.
….and heat
sixdogs has the answer.U ain’t kiddin…
….and heat
