sd455dan
Super Member
- Joined
- Oct 23, 2012
- Messages
- 6,390
- Location
- North Idaho
- Tractor
- Rhino 554, Ford 550 TLB (JD X500, MTD, Gilson riding mowers) Ford 3000-Sold
Finally hitched up the Up Shot Inverted blower/
Greased everything, and checked tensioner and reset the rotator gear clearance.
Made a guide support for the chute deflector, so that the hydraulic lines stay clear of the gears when the chute is rotated.
Fun job used the MIG to weld a 3/8" bolt in tube and then turned the flat on my repowered lathe. Then welded a left over piece of my shortened QA springs from the 455 RX7 as an easy guide , (knew that spring end would come in handy for something how many times I almost threw it out).
Just need some black paint.
Next is an oil and Filter change.
ps. Really Like how heavy and well built this Wifo is, even if it isn't the newest style hybrid Inverted, If it works as well as last year there won't be any complaints.
