Bucket super slow dumping
/ Bucket super slow dumping #1
gregshade
Oneida, TN
tbd
Spread 42 tons of gravel recently with Mahindra 3036 and lately noticed bucket dump being very very slow.
I don’t see any hydraulic leaks. What further troubleshooting should be done to identify the problem?
Thanks!
/ Bucket super slow dumping #2
Are you running the throttle too low? Rev it up a bit and see if that increases the dump speed. Also check the fluid level.
/ Bucket super slow dumping #3
Couple things to check
Does the engine sound like it is straining while trying to dump? If yes then place loader on ground with engine off move joystick to remove all the pressure then unhook and recconect the two quick disconnects on the dump cylinders. If one of these is partially connected or failing it can cause slow movement.
If one QD is starting to fail it will act like check valve in one direction.
2) ensure that the joystick is moving the directional valve fully. Occasionally something can loosen and prevent full spool travel.
Engine rpm doesn’t improve performance. Fluid is full. Thx
Thanks, I’ll give this a try.
/ Bucket super slow dumping #7
x2 on checking the quick couplings.
/ Bucket super slow dumping #8
3X on the quick couplers! I wasted months having the spools looked at and rebuilt and then one day I stumbled on this. Ugh.
Swict 72in Bucket Skid Steer Attachment (A64553)
Swict 72in Bucket...
2021 MOROOKA MST2200VDR TRACKED DUMPER (A65053)
2021 MOROOKA...
2007 Chevrolet Silverado 1500 Pickup Truck (A64194)
2007 Chevrolet...
HEAVY DUTY MILITARY TENT (A63276)
HEAVY DUTY...
2017 Ford Explorer AWD SUV (A64557)
2017 Ford Explorer...
L6060 Kubota For Sale
