John Deere 790 injector pump parts
   / John Deere 790 injector pump parts #1
cjzielinski
John Deere 790
OK, I need some help locating parts or a rebuild kit for a John Deere 790 injector pump. In the back of the pump, where the fuel solenoid comes into contact with the fuel shutoff inside the pump, there are two springs that are worn out. When the solenoid activates, the springs are too weak to push the level back and allow fuel to the engine. I can take the solenoid off and pull the shutoff level back with a pick, and it starts immediately. I have cleaned all of those parts, and you can tell the springs are weak. The pump model is 7929223 51470. If anyone knows where I can find a rebuild kit or even those two springs, I would appreciate the help. If those springs are all I need, I would rather not spend $1000 on a rebuilt pump.
   / John Deere 790 injector pump parts #2
You can send you pump out to be rebuilt for a fraction of the $1,000 and be so far ahead and the machine running.
Your engine is a YANMAR, so Mike is the guy who knows it all.
Mike the pump guy - Master Injection Pump Rebuilder
For Japan made tractors, namely many of the brands including Yanmar for fuel pumps and hydraulic pumps.
Mike can be reached on TBN from time-to-time, The best way is via email he typical monitors very often at:
thepumpguyscATaol.com
(replace the AT with the @ symbol when emailing please)
- Mike has 35+ years in the industry with injection pumps and hydraulic systems.
- He is very well versed in the JIS and SAE standards for parts to ensure proper components are used for rebuilds.
- From Sunny South Carolina.
- When sending parts via mail, please be sure to have insurance for a bit more than what you can find it new due to carrier issues that 'could' happen.
There are many positive testimonies on many of the Industrial Equipment, Heavy Equipment, diesel boating, tractor and other forums on his work and professionalism.
Shout out to The Pump Guy | Heavy Equipment Forums
(2) Thepumpguysc rocks - TractorByNet
Timing fuel injection pump - Yesterday's Tractors (yesterdaystractors.com)
Ford 3600 leaking from where fuel inlet meets injector | My Tractor Forum
The Pump Guy - Yesterday's Tractors (yesterdaystractors.com)
2020 John Deere 60G- Hydraulic thumb- Case Drain- Angle Blade (A50397)
2020 John Deere...
2025 JMR 40in Stump Bucket Skid Steer Attachment (A49346)
2025 JMR 40in...
12-Wheel Pneumatic Pull-Behind Asphalt Compactor (A49461)
12-Wheel Pneumatic...
2014 Big Tex 12ft. S/A Utility Trailer (A48082)
2014 Big Tex 12ft...
2014 UTILITY 53X102 DRY VAN TRAILER (A50046)
2014 UTILITY...
2023 CATERPILLAR 259D3 SKID STEER (A50458)
2023 CATERPILLAR...
