Sleep apnea, CPAPs and other sleep health solutions.
/ Sleep apnea, CPAPs and other sleep health solutions. #101
You can use the SD card yourself, as I have on the last two machines, for OSCAR SW to look at my own data. DR. cant see this unless you have WiFi modem, App on phone, or hand it to them. So easy to keep private and use as you want.
/ Sleep apnea, CPAPs and other sleep health solutions. #103
I program all my machines myself. The information is readily available on the net... I own all of them outright as well. Not gonna pay some rental fee, ever.
/ Sleep apnea, CPAPs and other sleep health solutions. #105
After spending last weekend at the deer lease with a packed hunting cabin. I've started a CPAP collection fund for a number of the members. WOW! What a chorus of snoring, snorting, choking and other sounds. :rolleyes:
/ Sleep apnea, CPAPs and other sleep health solutions. #106
When I saw this thread, it caught my attention immediately. I have been on CPAP since 2011 and firmly believe it saved my life. I was having every sort medical problem imaginable. My blood pressure was out of control, I was having dizzy spells and even almost passed out at work, was taken to ER with BP 230/120. I had constant chest pain and was always tired. I would come home from work and sometimes my head would almost fall in my plate when eating supper. I was taking my blood pressure multiple times per day and charting it for my Doc. I had a heart cath done at the end of 2010 when I went to the ER from falling out at work. The Cath showed no blockages. Finally in the middle of having every kind of test possible done, I went to a sleep lab. I clearly had Obstructive Apnea. I was prescribed a machine, and the very first night I slept with it, I felt better the next day. Over time my dizzy spells went away, the chest pain lessened, and my blood pressure started coming down. In fact my sleep doctor took a look at the BP chart I was keeping and was really impressed. My BP started falling immediately the very next day after I started on the machine. It fell about 10 points in the first three weeks of usage. He copied the chart and used to to show other patients. The bottom line was I had been severely sleep deprived over a very long time. I certainly didn't believe that a sleep disorder could cause all the serious syptoms I had, but now I am a believer. I am inserting the chart of my BP when I started CPAP.
/ Sleep apnea, CPAPs and other sleep health solutions. #107
@BCinVA my story is similar except I wasn't really having BP issues. I couldn't function mentally after 1pm every day.
I would literally stop at a rest stop on the way to work to try to take a nap.
I've had mine since 2010 and believe I wouldn't be here without it. Even though I hate it, it is a love-hate relationship 😆
/ Sleep apnea, CPAPs and other sleep health solutions. #108
It was just yesterday when I learned that cleaning with ozone breaks down the foam and can do that in any machine so I've never used ozone but it seems to mess things up.
I use hydrogen peroxide.
Doesn't get near any foam.
Didn't go without notice how the "O2 cleaners" have disappeared from TV ads.
/ Sleep apnea, CPAPs and other sleep health solutions. #109
Has anybody one this forum used a Raspberry Pi to control the CPAP because you didn't like the menu selections offered by the manufacturer?
For example: I hate when my mask leaks and the machine goes to full air pressure. I would far rather have it lower the pressure till the mask isn't leaking anymore. I have my max pressure set at 14 but I've seen it as high as 17 when the mask leaks which just irritates me.
Another example: If the CPAP machine can sense when I go to sleep it should be able to sense when I wake up and turn the air pressure right down to the lowest setting. After all I'm not going to have apnea if I'm awake.
/ Sleep apnea, CPAPs and other sleep health solutions. #110
These devices have to be certified, so they try not to provide interfaces for anything.
The manufacturers do have ways of feeding back requests, but I am sure that would be slow.
/ Sleep apnea, CPAPs and other sleep health solutions. #111
Have you looked at other models, and / or talked to your doctor about changing the settings / profile? I don't know that the first is do able, but the second certainly is on some units. Changing the parameters is changing the prescription.
CPAP machines are medical devices, and as such tightly regulated by the FDA, so you aren't going to see much sharing on how to reprogram one as that tends to get the attention of the FDA and medical boards quite quickly.
My $0.02 is talk with your doctor about what could be changed, both in terms of prescription/ programming and the mask / headset for you. Slight changes in mask and fitting can make a big difference.
All the best,
Peter
/ Sleep apnea, CPAPs and other sleep health solutions. #112
The medial industry has told people that is not normal.
Snoring is normal.
The only thing that is not normal is not going into rem sleep. If you don't get rem sleep, then yes, something should change. If you have to take a nap in the middle of the day. That's your sign.
/ Sleep apnea, CPAPs and other sleep health solutions. #113
I'm due for a new machine so my thoughts were to keep the old one and eliminate their interface on it completely and design my own.
At this point I'm frustrated enough that I really don't care if it's certified or not. I know I need it though as I'm loosing weight the need is definitely less. I don't mind wearing it either as I do get a better sleep.
/ Sleep apnea, CPAPs and other sleep health solutions. #114
All the best,
Peter
Like I say I'm due for a new machine but if it's not an improvement then what's the point.
As others on this thread have done I've gone into the machine and changed some of the parameters. That has definitely been an improvement.
I will talk things over when I get my new machine but I'm not expecting to be totally happy. I was wondering if someone else had been just as frustrated as I am and if there was a way to improve the CPCP experience.
/ Sleep apnea, CPAPs and other sleep health solutions. #115
History recounts many examples of "two sleeps" each night. Art works depicting candle lit writers clothed in nightwear suggest the same.
I've always been advised to get up when I wake up, then return to bed again when sleepy.
It's hard, but works.
I sleep best after a full day of physical activity.
My wife snores, I love knowing she is safe and warm beside me.
/ Sleep apnea, CPAPs and other sleep health solutions. #116
So, do you have an s9 now? My understanding was that that ResMed's machines have settings for tapering pressure, but I'm not an expert.
I think getting the issues that you are asking for are completely reasonable, and some like getting the right mask and fit ought to be doable.
All the best,
Peter
/ Sleep apnea, CPAPs and other sleep health solutions. #117
Just came upon this post and I've been a CPAP user since 2020 at age 72.
My journey began when I suspected having apnea episodes and my wife noticed that I appeared to pause often in breathing while sleeping. Apnea episodes can affect ones blood O2 saturation levels, so I bought a Wellue O2Ring from Amazon to monitor O2 levels while sleeping. Generally O2 sats that go below 88% for a period of time can be a sign of a sleep related breathing problem. I was getting nights where my O2 sats were frequently down around 80%. I took the data from the O2Ring to my PCP and without hesitation he got me scheduled for a sleep study. I did two nights, one to determine if there was a problem and a second with titration. Diagnosis was severe apnea.
I ended up getting a Philips DreamStation not too long after and used that for almost a year until when it was recalled. I hadn't used an ozone 'cleaner', so I didn't have any reservations about continuing to use it until I received a replacement DreamStation 2 which I have and use currently. I wanted a spare CPAP in the event the DreamStation 2 failed and to have for travel. I bought a low hours Resmed Air Sense 10 Auto from a seller that frequently has machines on a CPAP forum (CPAP and Sleep Apnea Message Board | CPAPtalk.com).
One unexpected improvement I've had in a nights sleep is I use to make about 4 trips to the bathroom at night due to apnea arousal's. The CPAP has controlled the occurrence of the apneas and I'm down to usually just one bathroom wakeup call now.
I still use the O2Ring to monitor O2 levels and heart rate and if something looks off I'll use OSCAR software to see how the nights sleep looks. The image below is a screenshot of my O2 sat levels prior to starting CPAP.
/ Sleep apnea, CPAPs and other sleep health solutions. #118
It takes me weeks when I get a new CPAP.
Mine allows me to have a range, which is senses, and that makes a big difference.
Mine varies from 9.5 to 11 based on data with range set 9-15.
I was lucky in that my nose pillow mask fit me well from the start, tried a few others and they did not work as well for me.
It would be nice if you could pre-try a few machine/mask combinations, but the costs and cleaning process would make that prohibitive.
I also buy my own machines after the insurance companies/medical companies always tried to give me a lesser model for a lot more money. Common scam, Machine I could buy outright for $600 was charged about $1500 to the insurance company..So bypass that, more out of my pocket, but so far I have been on better machines that work well for me.
/ Sleep apnea, CPAPs and other sleep health solutions. #119
All the best,
Peter
Yes I have a S9 now. Someone here kindly sent s link so that I could download the clinical manual and get into the appropriate menus without making a mess of things.
My issue isn't with the mask but about once a week I end up sleeping with my mouth open for a while. When I wake up my mouth is thoroughly dried out and that makes me a bit growly. That the CPAP puts out more pressure to counter act this makes no sense at all.
I'm anticipating an interesting conversation with the clinician when I go get my new CPAP. The two times that they have set it up they made some stupid mistakes. The first time setup the CPAP wasn't set for auto pressure and would just blow at 17lbs all night long after the ramp up. The second time they set it up the auto pressure was enabled but the max pressure was set at 20. That was rather uncomfortable as well. When I got into the menu I set the lowest pressure right down to 4 and I would set it lower if I could. I set the max pressure at 14 which is considerably more comfortable. Like I say it'll be an interesting conversation.
/ Sleep apnea, CPAPs and other sleep health solutions. #120
Good luck, getting the manual is my first step as the Dr. usually don't know the specific equipment that well
1981 LINK BELT HSP 8028 (A58214)
1981 LINK BELT HSP...
2014 INTERNATIONAL PROSTAR+ (A60736)
2014 INTERNATIONAL...
2019 GALYEAN...
2006 Hummer H3 4WD SUV (A61569)
2006 Hummer H3 4WD...
2021 Kubota SVL75-2 Track Loader (A61307)
2021 Kubota...
2014 Freightliner M2 106 Palfinger PK22002EH 6 Ton Knuckleboom Flatbed Truck (A55973)
2014 Freightliner...
