BX2200 no crank
   / BX2200 no crank #1
NYTrainer
Long Island, NY
Kubota BX-2200
I think the gear selector (hydro) is out of adjustment (assuming there is a safety interlock there).
I know it needs to be in neutral to start. No crank 2 days ago (no clicking of solenoid by the way) so I moved the hydro stick back and forth and it started. Today same thing but no amount of movement of hydro stick helped. I lifted rear wheel off the ground and tried to rotate tires. There was some resistance at first then they moved. At that point I tried key and it started right up.
Would like to know if there is a safety interlock for this hydro stick (seems obvious as it won’t start unless in neutral) and where it is. I also would benefit from an electrical schematic of these safety interlocks.
I’ve had the BX from new (2001) and have really never had much trouble with it (900 hours).
Thanks for any help.
   / BX2200 no crank #2
Sent PM with the info you seek
   / BX2200 no crank #4
Because the material is only online for a short time period. Someone reading it month later would find it useless.
   / BX2200 no crank #5
LOL. Not sure what planet you live on, but I can tell you that posts I have made here probably almost 20 years ago still show up during a search of TBN...
Meaningful posts here do not lose their value after a month.
Granted some links do become dead over time. So much better then to just share the needed information here without a link, if it was a link you thought would go dead.
   / BX2200 no crank #6
I uploaded some stuff to MY web/file server and those Files will be deleted during routine updates I do. I can not upload these files to this forum due to size restrictions and the rules.
So yes any link would go dead quickly. a week maybe
2014 Nissan Altima S Sedan (A55853)
2014 Nissan Altima...
2010 Turfco Mete-R-Matic III Pull-Behind Top Dresser (A51691)
2010 Turfco...
78" ROCK BUCKET (A52706)
78" ROCK BUCKET...
2018 MACK CHU613 DAYCAB (A53843)
2018 MACK CHU613...
2001 BOMAG BW141AD-2 SMOOTH DBL DRUM ROLLER (A52707)
2001 BOMAG...
