Backhoe experts?
/ Backhoe experts? #1
repete
SW Washington
L2550DT IH584-4WD
I have an L2550DT with a 4520 backhoe.
I like the subframe backhoe unit and am curious if anyone knows what other Kubota models this backhoe may fit on.
/ Backhoe experts? #2
It should list compatible models in the install instructions which should be available from Kubota
/ Backhoe experts? #3
I did not know that Kubota made a subframe for the L2550 and that hoe. Got any pix you can post?
Here is an L2550DT I owned many years ago, where I installed a Woods subframe to mount a Woods clone hoe. The subframe was way too long and the hoe stuck out too far to the rear.
/ Backhoe experts? #4
Note that the L2250DT, L2550DT, and L2850DT are identical, except for the engines.
/ Backhoe experts? #5
will fit on many as long as a B-4521, L-4523,B-4524, or the L-4525 mounting kits can be directly fit or fab'ed to fit.
