Straw over grass seed
/ Straw over grass seed #1
WVH1977
Richmond, VA
Massey 2860M Cab, Massey 1E.35, Gravely Pro-Turn 560, 1989 Ford D47 Dump Truck John Deere LX178
I have always put straw down over my grass seed after planting. Just planted some more of my yard and thinking about not putting straw down. Does it matter and will it make a big difference?
/ Straw over grass seed #2
Yes, it will make a difference in the wrong way. Straw helps retain moisture. Seeds left in open sun will dry out. Also helps keep the seed-eating birds Reduced a bit
/ Straw over grass seed #3
You will get a much better seed germination rate by using the straw. In addition, seed will develop a stronger root system quicker and thus be able to stand adverse temps better. Ken Sweet
/ Straw over grass seed #4
I agree that seed needs to be covered because of the reasons you described. But straw isn’t the only option. I have used peat moss successfully once, and another time I scattered a thin layer of potting soil over the seed. A little neater because these don’t have to be raked up once the grass is established like straw.
/ Straw over grass seed #5
I’ve never raked up straw. It decomposes eventually. And those other methods might work fine for a small area straw is the only practical option for a large area aside from hydro seeding.
/ Straw over grass seed #6
“potting soil”? I mean I guess on a little patch of missing grass, but over a large area? Also, wouldn‘t that just get washed away and expose the seeds after any appreciable rainfall?
I have never removed straw after planting seed. Why would you do that?
Straw can be hand-shaken from bales or put into a straw mulcher and shot onto the ground And it will stay there for over a year, unless it’s on steep ground or wind blows it away before it gets “rained down”.
Straw will keep doing its’ job long after potting soil has washed away.
/ Straw over grass seed #7
Hay is my first choice, but straw is better than nothing.
/ Straw over grass seed #9
It certainly helps to mulch seeds after broadcasting I always try to do it unless I am doing a large area
/ Straw over grass seed #10
Also hay is much better as it sticks to ground better and has grass seed in it.
  • Good Post
Reactions: JJT
/ Straw over grass seed #11
I’ve had problems with a lot of weed seeds being in straw. Maybe on flat ground you can get away without the straw if you keep it watered.
Same here. But I guess it depends on the quality of the straw. I ended up with a yard full of "weeds". It took a while to eliminate the weeds.
/ Straw over grass seed #12
I guess definitions of "large" can vary. I use straw on smaller areas, up to 1/2 acre. If doing anything larger than that, it's too tedious. For larger areas, there are two methods that work better:
1. Sew in annual rye, which will blast off in just 3-4 days if watered daily, no straw needed. Two or three weeks later, aerate and overseed with your permanent seed, usually tall fescue for my clime.
2. Seed with an 80/20 mix containing 20% annual rye. Same effect as above, but a quicker 1-step process. This doesn't always work quite as well, since some of your good seed can wash away in a single big rain event, before the rye germinates.
In both cases, the fast-germinating annual rye grass is serving to stabilize the soil, prevent erosion and loss of your good seed, and provide the same shade and moisture retention as straw would do on a smaller area.
/ Straw over grass seed #13
Depends also on quality of seed. I've had new plantings come up with a lot of weeds from cheaper seed, even without straw.
Weeds are easily eliminated in a single season. Just hit with lawn weed control (Escalade 2 or Surge) after first 5 or 6 mowings, timing for when lawn is well-watered and not stressed, or spot control with a lawn weed control for individual weeds.
/ Straw over grass seed #14
I renovated my lawn this past July. I just seeded heavy and used a roller to pack the seed into the ground. Then went over it by lightly spreading fine soil over top in a a very thin layer with a spreader. This is what it looks like now.
/ Straw over grass seed #15
Good job. I'm guessing maintaining a lawn in NM is all about irrigation and choosing the right varieties for managing your dry climate.
We are normally pretty wet here in eastern PA, but have a brutal 6 weeks of no rain and 85-95F sun thru all of July and the first half of August. Grasses that favor dry and hot die in our cold winters and wet autumn or spring, but grasses that show high survivability in our winters tend to brown out or even completely die in our July. doh!
Here's mine after the last of the year short mowing, just as it's turning dormant for winter, as you can see from the bit of brown thatch. I mow longer in summer, 4"+ for tall fescue in heat, but take it down near 3" (as shown) for winter to avoid snow mold.
I maintain 3 of our 4 acres like a cheap golf course, with the remaining bit always looking rougher due to all the firewood I move and process. All by chemical management, mostly just an adaptive fertilization and pH balancing schedule, I don't get down on my knees to pull weeds. :D
I have winter rye and though about this. I might do this.
/ Straw over grass seed #17
I would consider more than 100 sf “large” enough than I’m not raking around Pete moss or something like that. A straw blower will increase the area covered by straw to as much as you want to do.
/ Straw over grass seed #18
Straw works excellent, I’ve also had very good results using lawn clippings but it’s extra work.
/ Straw over grass seed #19
Nice job, and a large lawn. Mine is small (50’x100’) and the remainder of the land is just native grass that I mow occasionally. My lawn is a mix of Kentucky bluegrass and fine fescue, but I’m at 6,800’ elevation so warm season grasses won’t survive the winter. These are more water hungry grass species than the tall fescue and Bermuda grass that they use at lower/warmer elevations. But I have my sprinklers set to water for 20 minutes, every other day, so not too bad for water use. During a normal summer monsoon season (July-September) I either don’t water at all, or only once per week. I fertilize 3 times: early spring, midsummer, and fall. I do use weed killer, but only spot application. I have a tree stump in the lawn as a result of broadcasting weed and feed fertilizer several years ago.
/ Straw over grass seed #20
Straw blower? Have to admit, I'd never seen one. Around here, for lawn usage, everyone I've ever seen just separates and spreads the stuff by hand. Great for 1/4 acre, but hell for 3 or 4 acres. Many also use factory-assembled straw mats, often woven together with monofilament fishing line, which should be banned, IMO.
Agreed on the peat moss. Not only does it sound like work, but I don't think it's necessarily the best thing for a new lawn. It can improve soil structure and drainage, but there are better products for this.
Very cool. I actually looked at irrigating a few large areas of my lawn, which tend to brown out in our usual summer draught, and have even completely died two or three times in the last 30 years. But the water usage is just enormous when you start looking at providing sufficient water to multiple acres, living off a well. We settle for just irrigating our younger trees and shrubs, and keeping the swimming pool topped up. I think we use ~130 gal/day on tree irrigation + 600 gallons per week on the pool.
2020 INTERNATIONAL MV607 REEFER TRUCK (A67714)
2020 INTERNATIONAL...
Unused 2023 Land Pride RCF2060 5ft. Rotary Brush Cutter Tractor Attachment (A66734)
Unused 2023 Land...
500 BBL WHEELED FRAC TANK (A67714)
500 BBL WHEELED...
2000 FREIGHTLINER CENTURY CLASS DUMP TRUCK (INOPERABLE) (A67714)
2000 FREIGHTLINER...
2021 JOHN DEERE 304L WHEEL LOADER (A65056)
2021 JOHN DEERE...
BOAT MOTOR (A66738)
BOAT MOTOR (A66738)
