Bleeding hydraulics
/ Bleeding hydraulics #1
Eggsiam
Bryant, Washington
1984 Iseki tu1600 4wd mini tractor
Anybody know how to get the air out of hydraulics on Iseki tu1600??
/ Bleeding hydraulics #2
Most hydraulic systems don't require bleeding. The air makes it back to the supply tank via the return line. Are you having trouble with your hydraulics?
/ Bleeding hydraulics #3
Agree. Thinking that they need bleeding usually means there is another problem. It's an open center hydraulic system - as in "open to the atmosphere via the sump vent - so they generally bleed themselves in a minute or two of operation. It's possible I guess, but I've never seem it. And I've done my share.
rScotty
/ Bleeding hydraulics #4
Hydraulics should self bleed within a few cycles. If they don’t the pump is probably still sucking air.
/ Bleeding hydraulics #5
Exactly. Next thing is how and where to look for a suction leak. Those type leaks are very common, and a hydraulic system with a suction leak will work just well enough to drive you nuts.
rScotty
/ Bleeding hydraulics #6
I had a leak at my coupling and you could not tell at all,A stick had bumped the ring back just enough to open it a bit. I noticed it by a weak function.All I did was remove and reattach and it was leak free. Check every coupling even if they look coupled.
