Hydraulic/Trans fluid
/ Hydraulic/Trans fluid #1
Whitetail Freak
Mahindra 2810
I just acquired a 2810 I didn't get any manuals with it. So I looked up the service manual on the Internet it gives certain brands. All I have is a tractor supply and a Napa. My problem is which oil to get for this tractor I know it has wet brakes also. If someone could tell me which oil to buy and what spec oil mahindra calls for would be greatly appreciated.
/ Hydraulic/Trans fluid #2
Unfortunately, there are not industry wide specifications and standards regarding transmission / hydraulic tractor oil. The TSC "Traveller Premium Tractor Trans/Hydraulic Fluid” will be fine in your machine.
The 2 fluids to avoid are straight hydraulic fluid (not intended for use in transmissions), and a somewhat dated issue, but old "303" fluid spec which is not suitable in any modern machinery. TSC was involved in the 303 debacle several years ago, but I believe they have since either correctly labled it, or just don't sell it.
Thank you much appreciated.
/ Hydraulic/Trans fluid #4
Warren Oil Co was the manufacture of the 303 and the settlement was 10.8 million. It was sold under various labels. They also manufacture Travellers brand. I would not use it. There are no standards for hydraulic fluid. No one is checking to see if it is what is represented on the label. I figure if an equipment manufacture puts their name on it, they probably know what's in it and may even have developed the recipe themselves. John Deere Hy-Gard should be very good. Case Hy-Tran would be another one. I'm sure Caterpillar has one as well.
/ Hydraulic/Trans fluid #5
Also, New Holland "Master Tran" (or Ultraction if I recall??)
Be prepared for some sticker shock.... (presuming you are not yet aware). For me, it's roughly $150 after tax for a 5-gallon bucket of Hy-Tran.
Found it 10/15 dollars less expensive when I found a small local dealer that I didn't know existed.... but they are a New Holland dealer. Happens that Case/IH now owns New Holland (as I understand) "Ultraction" is essentially Hy-Tran in a New Holland labeled bucket. I might have the names mixed up.... (happens!) but the point is New Holland is another location you can find good stuff.
I just did a 25 gallon flush on my tractor.... I'm still crying in my wheaties.
/ Hydraulic/Trans fluid #6
About 12 years ago had the main line from the hydraulic filter break on the Mahindra 3510 and it lost about 6-8 gallons of oil in a minute or two.
Had 15 gallons of the infamous 303 but was not aware of any problems with it. I guess ignorance is bliss. Tractor is still running fine.
Thanks guys for the feed back much appreciated.
/ Hydraulic/Trans fluid #8
Do you not have a Mahindra dealer close by? If not Dave's Tractor will ship it to you they are located in California, great dealer.
2019 Chevrolet Express 2500 Cargo Van (A64556)
2019 Chevrolet...
KING 3 BAR - 18 SHANK CHISEL PLOW, 3PT (A64278)
KING 3 BAR - 18...
ACS PORTABLE AIR COMPRESSOR (A64276)
ACS PORTABLE AIR...
2014 John Deere 350G Hydraulic Excavator (A64194)
2014 John Deere...
2017 Ford Fusion SE Sedan (A64557)
2017 Ford Fusion...
2010 Mertz Manufacturing 50003-02 T/A Fracturing Pump Trailer (A64194)
2010 Mertz...
