My tractor from hell injector pump troubles.
   / My tractor from hell injector pump troubles. #1
mx842
Richmond Va
Kubota L3301, PowerKing 2414, John Deere 316, Gravely ZT HD 52
I've been working on this tractor for a couple weeks now. At first all I had to do was change a leaking fuel shut off valve. I ordered three different valves and they were all wrong, so I took the guts out of one of the wrong ones and fixed that problem. I changed the filter and finally got it going again. It would sit there and idle all day but after about 10 minutes under load it would lose power and shut down. Long story short I finally figured out that the tank was rusty so I cleaned it the best I could. At that point I had not removed the shut off valve completely because I was afraid I would break off the fuel line going to the filter as it was really tight and hard to get to. I just opened the valve and let what fuel that was in the tank drain out into a bucket. Once it finished draining, I dumped about a half-gallon of clean fuel back into the tank and took a coat hanger with a rag on the end and sloshed it around hoping any remaking loose stuff would be cleaned off the sides and bottom of the tank. I could look in and it looked fairly clean.
Once that was done, I changed the filter again and before I got it started, I could see I had another leak this time it was coming out the bottom of the tank. I guess me cleaning the bottom of the tank that it rubbed off enough material to rub through.
So, I went on to yesterdays tractor and ordered a new tank and a few other things I wanted to replace. I got the tank and started the project, and it was a real pain to get all that stuff off. Before I put the new tank on, I replaced that old valve and fuel sender and that is when I found out what the problem really was in the first place, well other that the hole in the tank. There was no screen on the valve and the opening was packed full of rusty stuff. It would allow just enough fuel out to get it running but not under a load.
I got 4 bolts lined up to where I could get the bolts back in. I went to put the 5th bolt, the one that is at the bottom and that bolt hole was off by a full 1 1/2". After looking at it for a while I decided to just leave it out and deal with it later. I got the rest of the hood, steering wheel and wiring bolted back up. I called yesterdays tractor to see what they would do about the bolt hole that would not line up and they were not much help. At first, he said to send it back in and they would look at it to determine what could be done. I asked just how long that would take and the guy said probably about a month maybe two. Then he called me back and told me that since I had installed it, it couldn't be sent back. I raised a little fuss and he finally said well take a picture of of it and he would relay it to some other department. I sent him the pic and I haven't heard nothing else from them. Even if they would take it back, I would rather eat a dried-up piece of dog poop than take that stuff off again. The main reason I called them in the first place was to find out if I could re-drill the hole without causing another leak and he said he knew nothing about that. Anyway, I have no intention of taking it back off no matter what they decide especially after they told me they would not even pay for the return shipping let alone giving me any help for all my time. Now, after all that I want to tell about what has happened now. I guess getting all that other stuff fixed allowed a lot more fuel get through the system and once I got it running, every place on the pump that has a seal or gasket, is now leaking when it's running. A few years ago, I would have attempted to take it off and reseal it but now not so much. I guess I'll have to at least take it off and send it out to have it cleaned and re-sealed. The Lord only knows what else will screw up before I get this thing done. I already know I'll have to replace the muffler because it's loose and when I took it off to do this job I found a piece of metal had come off where it fit down onto the manifold just sitting there waiting to fall down into the manifold. This is why I hate working on old stuff. sorry about the long rant.
I’d be happy to help..
Lemme know what ur working on for starters..
U can contact me directly at
my screen name at aoldotcom
It's a 1973 Ford 3000 3-cylinder diesel with the CAV pump. It's hard to tell exactly where the leak is, I mean, I don't see fuel squirting out in any particular spot, but I can see a lot of fuel dripping from the bottom. When I first looked at it I thought it was coming out of the gasket that's on the bottom of the pump. After looking at it again yesterday it may be leaking from one of the injector lines going to the injectors. When I first started working on this tractor, I thought I could see fuel coming out of the #3 injector line at the pump and I tried to loosen it up and re-torque the fitting, but it would not budge. I was afraid I would ring off the line at the fitting, so I left it alone for the time being. I was going to replace all three lines once I got it running. I might just go ahead and order these lines along with a couple others that need to be replaced and see what happens. If there still is a leak, I'll probably have to send it to you to reseal the pump. I thought about doing it myself, but I lost every tool I owned when my building burned down last Dec. I've replaced some of them when the need arises, but I hate to stop and go get another tool when I'm working on something especially something like this.
   / My tractor from hell injector pump troubles. #6
Spray foot powder also works.
This just keeps getting worst. I had to take a break from this tractor for a day or two. I had ordered a new muffler, injector lines and a few other things and most of it came in a day or two ago. Yesterday I had a little time and decided to replace those injector lines and install the new muffler. The muffler went fine now it's nice and tight and not flapping all around. They said the lines were exact replacement but what a pain to get them all on and buttoned up. I did find one of the leaks and that was at the pump return line back to the filter. I had tried to loosen this line up before but didn't for fear of breaking something. I ordered a couple banjo bolts so I decided to go ahead and take the old one off and replace it with the new one. Well as luck would have it something did break, where the banjo bolt screws into the pump there is what looks like an aluminum bung that is about 1" long with threads in it for the bolt. Well as I was trying to get the bolt loosened up that little Aluminum bung turned in the housing and now a small leak is a big one. I don't know if that housing can be replaced or what will be involved in fixing this problem. The # 1 injector line was where one of the leaks were but most of the leak was coming from this return line housing.
The tractor was running better than it has for years after changing that tank but then these leaks developed. At first, I thought about leaving it be but the more it ran the more it would leak so I had to do something about it. I'll have to do some pecking around to see what I'm up against now. Hopefully I don't have to change the pump after all.
   / My tractor from hell injector pump troubles. #8
Post a pic or send it to my email.. my screen name at aoldotcom.
I’ll help if I can.
   / My tractor from hell injector pump troubles. #9
Hey man sorry for your troubles, but gotta ask you, what is the picture in your avatar? Looks like a closeup of someone who got popped in the cheek during a fight…..
   / My tractor from hell injector pump troubles. #10
That’s not what I see.. lol
Did u send me some pictures.??
I received 2 but afraid to open them.. it doesn’t say ANYTHING about YOU, the machine, leaking inj pump, TBN..NOTHING..
Yes I did I may have sent two. Thanks
He,he,he......Yeah it was a fight alright I did a post a long time ago about it. I was bush hogging and ran over a nest of yellow jackets and those black and white hornets at the same time. They really lit me up. I didn't know they were there until I looked down and saw my shirt had turned grey to yellow and black and about the same time the pain set in.
I see on yesterday's tractor parts they have those covers. Now I'm wondering what's going to jump out when I take it off. They had a used pump on there for a little over $400.00 awhile back. I started to buy it but let it slide.
   / My tractor from hell injector pump troubles. #14
I opened up your pic..
I know where it’s leaking..
The return on the SIDE of the pump..
I have a new cover w the valve..
Contact me for the cost..
Normally I would give it away, but I HAD TO buy some..I was out..
   / My tractor from hell injector pump troubles. #15
What a disheartening story! Sorry for all your troubles bro! Things should get better from here.🙏🏻☮️✌🏻
   / My tractor from hell injector pump troubles. #16
Oh, nothing is gonna jump out.. it WILL BE full of fuel tho, so take off slowly to let it drain.. or just jump outta the way.. lol
Btw.. the cover on yt is pretty expensive.. like 30.00 more than u should spend..
What valve? Mark it down as sold and do you have the gasket..
   / My tractor from hell injector pump troubles. #18
Once u take it off, you’ll see it’s a valve..
I’m real good at fixing them if u wanna go that route.??
Yes I have the gasket.. I’ll throw it in.. I’m kool like dat.
well just let mt know what you want. There are a couple other things I asked about in those two messages I just sent to you. The plate they have on yesterday's they want $58.00 I believe but they don't say what comes with it.
TORO GREENS MOWER (A56857)
TORO GREENS MOWER...
2021 CATERPILLAR D5 LGP HIGH TRACK CRAWLER DOZER (A52709)
2021 CATERPILLAR...
2015 Dodge Journey Van (A59231)
2015 Dodge Journey...
2016 PETERBILT PB337 FLATBED TRUCK (A52706)
2016 PETERBILT...
Bobcat 873 (A55272)
Bobcat 873 (A55272)
2011 CATERPILLAR CP56 PADFOOT ROLLER (A60429)
2011 CATERPILLAR...
