Ink stains
/ Ink stains #22
I would never have thought a cig lighter would do that much damage.
/ Ink stains #24
If you're tempted to use solvents or alcohol, unplug the dryer and/or kill any pilots lights and shut off the gas first. Yikes.
Have you tried a Mr. Clean magic eraser? Crazy things remove just about anything from just about anything else.
/ Ink stains #25
Is that what Mods use now? :)
/ Ink stains #27
But seriously, I worked at a newspaper for 30 years, so I've had a few experiences with ink in the wrong place.
Fortunately, I always had access to blanket wash. It's what they use to clean the blankets and rollers and anything else with ink on it on the presses. It's a solvent. Has some cautions on the label. ;)
/ Ink stains #28
I would feel safer about trying to clean the dryer outside in a well ventilated area where the solvent could dissipate rather than a confined laundry room.
/ Ink stains #29
The old dry-cleaning fluid would get just about anything out--Grease, ink, glue, baby "stuff" and everything else. Not sure what they use now but I know it's not as strong. All the readily available strong solvents went away in the 80s. I still have about a case of some old AC system cleaner that's close to Carbon tetrachloride. It cleans everything too (And no longer sold). :rolleyes:
If the cans haven't dissolved, you'd be welcome to a can. You'd have to be close because I don't think it can even be shipped now.
/ Ink stains #30
My Dad liked carbon tet. Said they used to use it by the bucketful at the lab.
/ Ink stains #31
/ Ink stains #32
That stuff was nasty! 🙃
/ Ink stains #33
There are replacements for both carbon tetrachloride and perchloroethane, aka "perc" that are much, much, less toxic, but you have to do trial and error to see whether you need something on the hydrophobic end (paint thinner) or the hydrophilic end (acetone/ethanol) or something in between like MEK, or need to alternate back and forth. None of them are safe, though some are safer than others, and I would not want to use any of them in a confined space near flames or electricity. I can imagine that it might take more than a little while to get solvent back out of the dryer seals, and you might need to replace the dryer drum seals.
I am inclined to think that a new dryer really might be your best option, if Mr. Clean, and some elbow grease isn't sufficient.
Sorry.
All the best,
Peter
/ Ink stains #34
Acetone seems to be the ticket... just watch for ventilation and inhalation.
Skip to 10:00 in this video if you want to see how well it works, but I watched the whole thing just to see the other methods he tried.
/ Ink stains #35
If it were just my farm clothes in the dryer, no big deal. But some ladies are particular and some have a lot of money invested in what they wear.
LIGHT PLANT WANCO (NONE TITLED) (A63569)
LIGHT PLANT WANCO...
BOSS 990 Fuel Trailer - 990 Gallon Farm Diesel Tank, Field Refueling Solution (A63118)
BOSS 990 Fuel...
JRB 52" HANG-ON WHEEL LOADER FORKS (A63276)
JRB 52" HANG-ON...
2016 FREIGHTLINER CASCADIA  125 6X4 T/A  DAY CAB TRUCK TRACTOR (A59910)
2016 FREIGHTLINER...
2019 CHEROKEE TRAVEL TRAILER (A63569)
2019 CHEROKEE...
Toro Greenspro 1260 Towable Greens Roller (A56859)
Toro Greenspro...
