Generic DPF filter delete.
   / Generic DPF filter delete. #61
Really don't matter to me. I don't do emissions diesels anyway and never plan on it.
   / Generic DPF filter delete. #62
I was replying to the guy asking about Ecodiesel deletes.
Stan, I thought he was talking tractors since this is a tractor site. My tractor says Ecodiesel on the side of it.
   / Generic DPF filter delete. #63
Huh, interesting. The only Ecodiesel I am aware of is the trademark owned by Stelantis.
   / Generic DPF filter delete. #64
When I went to purchase a new tractor last year, I was terrified of the new Tier IV engines. Now at 275 hours on my NX, I am not as concerned. Would I like to go back to pre Tier IV, absolutely. But after the first year, I have not seen a real issue with the system. I don't idle any less than I used to with my 2003 Kubota. I let the engine warm up at around 1500 rpm. Once I get going, I generally stay at 2000 rpm or more. Regens occur at maybe every 30 hours or so. Usually they occur when I am in the middle of something, so no big deal. Only once did I have to park and let it do its thing for 20 minutes. Living in Canada, with temps regularly minus 20 or colder, it does take some time to warm up the engine to operating temperatures, but it doesn't seem to affect the time between regens. Having said that, I am almost always out for more than a hour at a time. If you are out for short bursts, that might make a difference. I do hope that before the DPF packs in that there will be an EASY way to bypass. That's what I like about this forum. There are always smart people that find answers and share with the community. PTSG, I do agree with you that people think they have to always have the engine pegged to avoid any problems. Don't overthink this Tier IV thing in my opinion. I do feel for those that are having problems with their system, but I am thinking it is a small percentage?? Thanks to all for sharing their experiences.
For real, you’re not going to see a problem in the first year hopefully. You are extremely likely to see a problem in the 5th year if you’re using the tractor.
I’d like to also say to those who think this is so naughty, that they should put another mask on.
Where’s the guy who is usually on these threads proclaiming that the dpf filter will outlast the tractor? That’s a big lol also.
I’ve owned dpf regulated vehicles since 2007 which has led me to have a quite negative view of the technology
   / Generic DPF filter delete. #65
This is on the hood of my tractor.
   / Generic DPF filter delete. #66
At around 770 hours my DPF filter had already been cleaned. Due to a turbo seal oil leak the DPF was considered junk by Kioti and replaced under warranty. Trust me I had my share of pains with regen problems and limp modes. So far since then it has been okay. I'm at 1201 hours as of today.
   / Generic DPF filter delete. #67
Sorry about the long post. Thought this might be the best place to find answers.
A friend has a 2020 Branson 4820R, manufactured date of 7/2020. He gutted the dog and turned the fuel up half turn. Runs very well and barely puffs a bit of smoke when cracking the throttle open fast. Since doing so, the dpf light and check engine light is on. At first it was just the check engine light. Then he disconnected the dpf control box and both lights came on. Along with loss of gauges. Connected the dpf box and gauges work but now the check engine and dpf light is on. Don't think there is much to worry about with the lights sense this is a mechanically injected engine.
Reason I'm asking is I have the same tractor and was thinking of doing this to mine. Is there a way to clear the check engine and dpf lights? Or just don't worry about them?
   / Generic DPF filter delete. #68
The only way is going to be to tinker with things and see what works.
I expect you have a differential pressure sensor and a couple of temperature sensors.
With a bit of ingenuity either the signals or the sensors can be fooled.
   / Generic DPF filter delete. #69
Tried unplugging sensors, plugging hoses, etc. Lights still stay on. Not that worried about it. We are just annoyed by the lights. Might try tracing the wires from the data logger that go to the gauges. The other wires should be for the dof system and could be de pinned from the main harness plug.
   / Generic DPF filter delete. #70
Maybe a clever person could come up with a piggy back adapter plug that only utilizes the dash gauges and not the dpf wiring. Plug that between the harness and data logger.
   / Generic DPF filter delete. #71
FWIW: My KIOTI CK35 with 250 hours and 2 years use- mowing 90% of the time at 2500 rpm. I always kept working during the regens every 25 to 30 hours....at 250 hours the tractor started a regen and quit then put me into "limp mode". Dealer required the tractor to be brought in and put on their computer to diagnose. Long story short-they had to replace the wiring harness because the computer was not getting a signal from the one of the sensors. Warranty work except I had to pay for the pickup and return to my farm. 6 weeks without the tractor during June and July mowing season:cautious:(n). Their story was it took about 2 weeks for KIOTI and the dealer to figure out the problem and KIOTI had no wiring harness available for shipping to my dealer for 3-4 weeks. Currently I am looking at TYM T2515h as a replacement for the KIOTI CK3510.
   / Generic DPF filter delete. #72
Glad you have your tractor back. I’m sure it sucked not having it when you needed it most.
However TYMs, or any other brand, break too. You’re up and running so enjoy the Kioti.
   / Generic DPF filter delete. #73
Bummer to hear about that. I suspect that continuing to do heavy duty mowing during regens would make for some VERY hot conditions under the hood. I presume you stay on top of keeping your radiator screen and front grille clear, yeah?
If you're happy with the rest of the tractors reliability and like the frame/size, did you consider the 2610 instead?
   / Generic DPF filter delete. #74
No butthead (Minnesota Eric), because it's Federal Law. It's actually a felony to alter emissions systems and likewise on cars and trucks if the vehicle won't pass an emissions test because it's modified, the original owner who did the modifications that render the emissions hardware / software not operable is still on the hook for necessary repairs to make the vehicle pass. But you aren't stupid, you already know that but chose to ignore it which, is you choice entirely.
Don't play ignorant. It's not becoming of a person of your 'intel level'. But, then, maybe it is considering your video's.....:)
I don't care what anyone does, you do own it (tractor or motor vehicle), just be aware that your actions can be used against you for compensation down the road if you ever sell it and the next owner has to have it certified or needs service at ANY dealer. Franchised tractor dealers will not knowingly work on an emissions modified unit when the repair consists of emissions components.
Why any 'chip' seller for a car or pickup or whatever states you need to pull that chip and restore the ECM to the original settings BEFORE taking it in for service at an authorized dealer diesel delete kit.
of course people disregard that, but then most people don't bother reading instructions anyway in as much as we live in a 'plug and play' society today.
That fine print will burn you every time.
I'm done with this thread. Do what you want but just be apprised of the ramifications down the road...
Why I don't own and never will own a post 4 diesel tractor. Both mine are pre 4 and how I like it.
Anyone use the delete kit from “DieselDNAtuning”.? Pipes and tuning is just over $1000, as compared to $2000 from Raw-tech/Malone. I know “you get what you pay for” but something like this seems like you could get away with it… thanks for input!!
2009 Hyundai Sonata Sedan (A59231)
2009 Hyundai...
1667 (A57192)
1667 (A57192)
2019 CATERPILLAR 420F2 IT BACKHOE (A60429)
2019 CATERPILLAR...
2014 JCB 930 (A53317)
PALLET OF SCRUBBER PODS (A58214)
PALLET OF SCRUBBER...
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A59230)
2016 Ford F-150...
