Good morning!!!!
   / Good morning!!!! #176,721
72F and cloudy @ 13:30 with a slight chance of a rain shower. That should be the high for the day ... (y)
Took dump cart up yesterday and grabbed some screened compost to use for potting strawberry runners.
When I got back down to the garden I had an audience:
Once I sat down and started to work they actually ended up wandering over even closer to where I was. Somewhat tame and pretty curious ... ;)
At some point I noticed the right tire (original) on the dump cart was flat ... :(
So I emptied out a bunch more of the screened compost into pots and set the back right corner up on a 6 or 7 gallon bucket and pulled the tire and wheel.
Woman ran it down to the local tire store and had them put a new tube and tire on it.
Was kinda surprised at how much they bent up the rim in doing so ... 🤬
After that more work on weeding and watering the strawberry plants.
Probably got another 30+ runners pinned and potted. Should be over 100 started now. Probably have at least another 30 I could start ... but Woman is getting impatient ... ;)
Watered all the pots as well.
Strawberries all seem to be doing very well for the most part, along with the beans:
Did not get any feeders filled yesterday so that's on the menu for today.
Probably go up and grab another load of screened compost and pot some more runners after that.
Next good chance (>50%) for rain looks to be this coming Tuesday/Wednesday, although there is decent chance (25%) on Sunday afternoon.
Yesterday's intensification of Hurricane Lee was pretty impressive ... hope it stays away from any populated areas ... looks to be pretty nasty. Seems like TS Margot could be a repeat performance.
Hope everyone is having a decent Friday ... (y)
   / Good morning!!!! #176,722
It shoule be spliced into the line at the point that the frame and the bodywork are closest, with the valve handle facing the sharpest edge of any available sheet metal (or where a self-tapping screw is protruding).
you want the installation to look factory, just like the an Automotive speeding engineer would design it, right? 🤣🤣
Correct - engineered for most difficulty to use
I’m going to place in engine compartment.
   / Good morning!!!! #176,723
"Once I sat down and started to work they actually ended up wandering over even closer to where I was. Somewhat tame and pretty curious ..."
Trust. :)
   / Good morning!!!! #176,725
I haven't heard anyone ask the question of where all the new electricity demand is coming from. Sun belt states like Texas have seen significant population growth, and that will put more demand on the grid. But that also creates more income for the utilities, income that should have been used to create more capacity. Has that not happened, perhaps because of "green" thiinking? As I recall, the green movement has only had a significant say for the past few years, and as Frits pointed out, construction plans should have been in the making for much longer than that. But the bottom line is this: If you want reliable, 100% always on electricity, you've got to make it yourself. And you won't be saving any money in the process.
Interesting twist to the request to save on power in Texas is that they requested wind power generators in South Texas to curtail output because the transmission lines into central Texas were overheating and paid the wind power producers for the lack of sales. They also have a history of paying Bitcoin farms to shut down to save capacity
   / Good morning!!!! #176,726
Ron, we are almost identical
I went on PECO's site and they told me
I consume $5.29 a day on average.
I average 1029kw per month. Average daily use 32.5
complicated bill composed of generation and transmission portions.
I'd be a lot happier paying their bill, which admittedly is about a third of the NC farm,
if they buried the residential lines. I lose power here at least once a month, sometimes once a week.
Always due to trees falling on lines.
I hear some rumbles, might get a little rain but otherwise today was a dud for precip. And hot.
I mowed the lawn this afternoon, felt good to get back inside.
up and out early tomorrow to take car to dealer for oil change and new brake pads.
Fronts need them at 51k, pretty reasonable. Will tell them if rears are more than 50 percent worn, replace them also.
on delivery had a braking shimmy so they put new front rotors on several years ago.
They wanted to replace the plugs since that is part of 60k service. It runs fine, and only has 51k miles.
I don't think so. Next year, another year, will be just fine.
I think they will give me a loaner car so I don't have to wait for it.
I always ask for a P1800 and get a good laugh.
then off to get my monthly haircut on way home.
had stuffed peppers for dinner. Pleasantly stuffed now myself.
   / Good morning!!!! #176,727
Our Mitsubishi mini split installed last year has operated perfectly. Oversized for cooling to give more capacity for heat has worked out really well.
PT lady is single, late 20's, ex Army, very pretty and like the rest of the ladies there, wears skin
tight pants. And oh the curves. Marvelous curves. Eye watering so well toned curves.
Curves I can't look at. She could be my granddaughter.
Good Evening Guys,
m7040, I installed a Fujitsu Mini Split unit in my Ct home 3 years ago. We are very pleased with the performance of the unit ! The head on the first floor is 18K BTU, and we have another head on the second floor in our master bedroom that is 9K BTU. I believe the main unit could support one more head, but this works for just the two of us. We bought it mainly for the AC in the summer but the heat was a bonus in the cooler months !
Drew,
You really have a latent writing talent, I couldnt stop laughing reading this description ! Thank you for providing some late afternoon humor for another old guy !:)
PopG,
Beautiful job on those pork shoulders, I have not run my smoker in some time, Im guessing its time to bring it out this fall and try a pork shoulder !
   / Good morning!!!! #176,729
Grilled some burgers for supper. Been rumbling from storm going up east of us. Didn’t get too hot today, only 91. I sat on porch till after noon, before computer work in afternoon. Did get a couple tiny tasks done.
So far happy with new mesh system in the house.
Generac XG8000E Generator (A55973)
Generac XG8000E...
2024 Ex Mark Lazer Z 60in. Zero Turn Commercial Mower (A55973)
2024 Ex Mark Lazer...
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A56436)
2006 Magnolia Dry...
Year: 2014 Make: Chevrolet Model: Silverado Vehicle Type: Pickup Truck Mileage: Plate: Body Type: 4 (A55852)
Year: 2014 Make...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2016 Club Car Carryall 710 Electric Utility Cart (A55853)
2016 Club Car...
