Crossed cables while trying to jump start.
/ Crossed cables while trying to jump start. #1
Moonshine Mac
Kioti dk45s
Accidently crossed the positive and negative cables while trying to jump start my Kioti Dk45s. Now i can't get anything when i turn the ignition key. Dash electronics are completly dead. No clicking noises, nothing. Any help?
/ Crossed cables while trying to jump start. #2
Must have either blown a fuse or fuse-able link. Will just have to track down until you find the break.
/ Crossed cables while trying to jump start. #3
Here is hoping that Kioti built protection into their units. Electronics do not like having the voltage reversed.
Had a customer this week post in our forum for VW cars that they did the same. Lots of control modules in the car were smoked. Felt bad for the guy. He is living a painful error.
My hope for you is that it is only a fuse!
/ Crossed cables while trying to jump start. #4
If the diodes in the rectifier get fried the alternator can then send AC current out in the system, cooking other components. Ye$, it can be costly.
/ Crossed cables while trying to jump start. #5
Check fuses, there may be a master fuse that is blown, owners manual should show wiring diagram and location and value of fuses.... Probably looking for a 40 to 60 amp "main" fuse....
According to this PDF file there is a slow blow fuse coming off the battery/starter that supplies power to everything electrical... Might check it!
Also....
  • Kioti electrical diagram.PDF
/ Crossed cables while trying to jump start. #6
I did this accidently, hurriedly swapping out a battery and wasn't paying attention and put the wires on the wrong posts. It blew the main fuse near the starter.
I'm guessing you have done the same thing.
Pretty sure it was a 40amp. But mine was a small Case IH DX24e SCUT
/ Crossed cables while trying to jump start. #7
Crossing the jumper cables doubles the Voltage on the system: 2 x 12 Volts = 24 Volts! Voltage is pressure to push electrons through the electronics. It can fry a lot of components, in a short amount of time... It is possible the maker put in a protective circuit, to prevent over-voltage damage from reversed cables. It costs them money to do that, so they may not have done it.
If the fuses do not fix it, you are likely looking at replacing circuit boards. I was an Electronic Technician for 3.5 years, doing component level repairs -- replacing resistors, diodes, transistors, capacitors, etc. I worked on Switching Power Supplies for computers: high wattage, high voltage, with literally explosive failures. It was always fun to turn on a repaired Power Supply for the first time, to see what happened... I wish you the best of luck. Cheers!
/ Crossed cables while trying to jump start. #8
There’s no way to get 24V, wiring two batteries in series, with only a set of jumper cables. Well. I suppose you have 24V right until you connect the last clamp.
You’re really only shorting two batteries, and/or the charged battery is overpowering the dead one, and dead vehicle’s components get a reverse polarity.
Diodes, if present, can ofer protection from this depending where located in circuits.
/ Crossed cables while trying to jump start. #9
You are correct. Sorry. Been too long since I worked as a tech.
/ Crossed cables while trying to jump start. #10
As other said...check fuses.
Do have meter? start at battery work your way back slowly
/ Crossed cables while trying to jump start. #11
Fortunate you didn't get a kaboom..!
/ Crossed cables while trying to jump start. #12
Totally clueless are we..... You don't get 24 volts you get more like dead short....
/ Crossed cables while trying to jump start. #13
The worry is as was posted earlier. Reverse biasing the Alternator output since you are making the alternator case "+" and the Alternator + battery output terminal negative that can forward bias the diodes into into an avalanche current condition since instead of the stator windings output you are now only limited by the jumper batteries ability to supply current which without some sort of an interruption (fuse) damages them, usually taking out the integrated voltage regulator as well.
Maybe the Op got lucky and the fusible link went open first. Here's Hoping. Many manufacturers place the fusible link very close to the starter in the B+ cable it may not be obvious because many times it is wrapped in a covering concealing that is not just a regular wire. A few manufacturers have placed the fusible link in the Alternators B+ cable in close proximity to the alternator or in the fuse box as a master system fuse. Heck these days not expensive to just place a resettable circuit breaker in line.
edit: it appears from Wranglers linked diagram a slow blow fuse should be located near the starter in the smaller B+ wire
If replacing that gets the tractor to where it will start then get out a volt meter and check that the voltage increases well above 12.6 VDC once the tractor starts to ~14.. If you have a meter that can read "true" AC switch it to that and make sure that there is not AC on the B+ line from the alternator.
If the diodes short, this can happen. Also even if the diodes survive good idea to also check that the regulator is in fact still regulating the system voltage. If it rises much above 15 VDC there is likely a problem with the regulator.
Hopefully nothing but the slow blow fuse went.
/ Crossed cables while trying to jump start. #14
You've probably already checked this, but in addition to the fuses, I would check the battery itself. shorting it to another battery in reverse polarity can fry the battery.
/ Crossed cables while trying to jump start. #15
As stated, it's very common for there to be a fusable link or a large fuse, that will blow in this circumstance. They are not always easy to find.
Without that protection, you can get a nice electrical fire going, pretty fast.
/ Crossed cables while trying to jump start. #16
Why would a fuse blow with reversed voltage? Fuses aren’t directional.
/ Crossed cables while trying to jump start. #17
Because of the alternator diode and any other diode or polarity sensitive device in the circuit.
The first drawing, negative ground battery when you close switch nothing happens.
Reverse battery leads, close switch and fuse blows. Diode is forward biased and draws lots of current.
The first negative ground drawing diode that direction current doesn't flow.
/ Crossed cables while trying to jump start. #18
Landhonor 72" Skid Steer Power Rake (A62679)
Landhonor 72" Skid...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
John Deere 2755 Boom Mowing Tractor (A66285)
John Deere 2755...
Keota MFG Bale Mover (A65640)
Keota MFG Bale...
Stout Buckets XHD84-6 Brush Grapple Skid Steer Bucket (A65640)
Stout Buckets...
2016 CATERPILLAR 926M WHEEL LOADER (A65053)
2016 CATERPILLAR...
