Midwest Gasoline to Spike $0.50-$1.00 Per gallon
   / Midwest Gasoline to Spike $0.50-$1.00 Per gallon #42
World markets determine prices, not just one country.
No. We have WTI for the US market. We have Brent Crude for other world markets. Then there is the Dubai/oman for other markets.
Not all oil is the same.
   / Midwest Gasoline to Spike $0.50-$1.00 Per gallon #43
123-75%=30.75
Where did you learn math. But lets check your work. If you take 30.75 and add in 75% to it (add a 1 to the % and multiply), what do we get? 30.75*1.75 = 53.81.
The way you subtract a percent from a whole number is...(add a 1 to the % and divide)
123/1.75 = 70.29
Check the math
70.29*1.75 = 123
You don't want to play in my sand box with me.
   / Midwest Gasoline to Spike $0.50-$1.00 Per gallon #44
Percent of a number, percent change from initial to new/current number, and percent difference are all different things.
If I had 10 apples and now I have 20, 100% increase.
If I had 20 apples and now I have 10, 50% decrease
   / Midwest Gasoline to Spike $0.50-$1.00 Per gallon #45
   / Midwest Gasoline to Spike $0.50-$1.00 Per gallon #46
Your V1 and V2 are backwards. Do it again reversed. ;)
   / Midwest Gasoline to Spike $0.50-$1.00 Per gallon #47
V1 is initial number (in terms of time old)
V2 is the new/final number (in terms of time new)
percentage change = (Vfinal - Vinitial) / Vinitial × 100%
   / Midwest Gasoline to Spike $0.50-$1.00 Per gallon #48
Just think about it logically and stop repeating what your website says. It obvious your confused.
The price dropped from 123 to 70. You can always check math, with math. So lets check it.
70 * 1.43 = 100.10
70* 1.75 = 122.5
Damn , this is not hard.
I taught math to undergrads while I was a grad student. There was always a kid on a hill that, even when presented with mathematical checks, would argue he was right. They never were.
We are here.
   / Midwest Gasoline to Spike $0.50-$1.00 Per gallon #49
This will not help the price of gasoline.
   / Midwest Gasoline to Spike $0.50-$1.00 Per gallon #50
70 * 1.43 = 100.10
70* 1.75 = 122.5
We are here.
Your chart.
12/2021 - $70
6/2022 - $123
3/2023 - $70
There was a 75% increase in value between 12/2021 & 6/2022
There was a 43% decrease in value between 6/2022 and 2/2023
If we are discussing percent change over time for a value. This is how it works.
If it was 50% decrease in value from 6/2022 to 3/2023 would have bee 61.50, 75% decrease in value 30.8, 100% decrease in value 0.
… the order of the values in the numerator doesn’t matter much, the correct denominator value is what is important, original/first value always goes in the denominator, provided you can figure out a negative number…
I don’t have any base math texts from grade school for a pure percent change formula that isn’t ‘from the web’, but here is a percent change snippet from Mechanics of Materials by RC Hibbeler from an entry level engineering class.
Not sure what you are trying to prove with this:
70 * 1.43 = 100.10
70* 1.75 = 122.5
70 with a 75% increase is indeed the same as 12/2021 to 6/2022.
(123-70)/70 * 100% = ~75%
Your proof however doesn’t reflect percent change.
2005 V.E. ENTERISES 130 BBL STEEL VACUUM TRAILER (A53843)
2005 V.E...
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A55852)
Pallet of...
2023 John Deere 6155M MFWD Tractor (A53485)
2023 John Deere...
2014 MAGNUM PRODUCTS LIGHT TOWER COMBO (A55745)
2014 MAGNUM...
air compressor (A55758)
air compressor...
2016 John Deere 326E (A47477)
2016 John Deere...
