mounted retail rems sentinel plate on 2010 GC2400 today
/ mounted retail rems sentinel plate on 2010 GC2400 today #1
Dmacleo
Etna, Maine
2010 MF GC2400 Owner, 2012 MF1532 User
bought this back in Feb 2023 just now getting to it.
kit (they ask if you have this) uses the factory u-guard if you have it.
pull that down (2 bolts lh side 1 bolt rh side) place adapter plate onto that frame and drill 3 3/8" holes.
use 2 bolts to attach rear side of adapter to factory guard then toss u-guard back in.
this was hardest part of job really, diff lock spring attached there on lh side and since I left tires on could not grab with anything. I cheated. I removed all 3 bolts lowered frame then removed spring, to attach hooked spring up then slid frame into place and bolted it up.
so now I am at u-guard in place/secure and adapter plate attached.
next up loosely attach the front guard plate. heres where I hit first issue. kit reqs 5 bolts. only 4 sent. no biggie.
so front plate attached then time for pto protection guard.
another issue (keep in mind only 2 issues and total 5 minutes fixing) the angle and bend (orientation) of the pto protector that hooks to fan shroud was WAY off. put it in vise spent literally under 1 minute getting it close, loosely attached it, tightened up front guard then tightened up pto guard and it all self formed into place. really if I was not disabled this would be a 30 minute install
tomorrow, since retailer told me MAY be possible issue with mower deck engaged at FULL lift, I will hook mower up and do interference checks. if needed can touch with grinder although since buying tractor in 10-2020 I have never run mower fully raised.
I went the retailrems (LINK) route over broteck (LINK) due to the cooling holes. no sense protecting your transaxle if gonna over heat the thing and burn it out anyway. local dealer has had to deal with warranty rejects due to guards blocking airflow. right or wrong...not my call.
I tested it, I pull 3 bolts (easiest was the 3 oem bracket to frame bolts) everything down for filter/fluid change. since I pull that bracket everytime anyway no change on my end mtx wise.
edit: got bored. mounted MF2326 60" MMM
pto shaft has a butt load of clearance.
and installation of guard in no way affected the hookup of the pto shaft.
when fully up rear fold of deck is between 5/16 and 7/16 clearance of everything. calling it good. a 331lb item (before grass buildup) ain't gonna bounce that much while mowing.
so I went mowing. I usually run the MMM with eng rpm at 1900-2000 rpm. means mid pto shaft not running 2K rpm, whatever.
today I was feeling frisky.
I put throttle to governor went full bore high range in area 9-12 inches tall. mowing at max speed 9.6 mph. little bouncy.
love the sound.
eng varied, even in SHARP turn, 100 rpm.
800x190 ft area of hay and clover as well as around spruce trees done in 15 minutes.
shield DID vibrate causing a noise but...no interference. 50 cents of 3/8 x 6 inches fuel hose slit will fix the noise.
/ mounted retail rems sentinel plate on 2010 GC2400 today #3
I am taking my old GC2300 to a different property where it will be used under more rugged conditions (brushhogging, moving downed trees etc.) and have been looking at this cover but geesh...6 months for delivery...and modifications.
Mine has the OEM version u-guard which was added by my dealer but I don't have a lot of faith in it since after moving some logs from downed trees, my oil filter is dented.
I also looked at this due to the ventilation holes but haven't contacted them yet.
Lou
/ mounted retail rems sentinel plate on 2010 GC2400 today #4
That was also my concern with bro-tek's design.
Lou
Just to clarify, I ordered in February and within 36 hours had email double checking year and model number of tractor.
I responded to email and within 3 hours was given instructions on mounting.
Just took months before I was able to mount it.
If my original post led you to believe there was a 6 month lead time I apologize. Not the case, communication and shipping were very fast.
Last time I looked under a gc2300 was in year 2006 but if you got factory guard I expect your installation matches mine.
edit: just to clarify, the only actual mod I did was bending one angle differently in a vise. 90 seconds from yanking out of tractor to putting back into tractor. serous you cannot go wrong with this item.
Yeah it's easy to stop crap from happening but not so easy to stop that and at same time provide cooling.
Ran nothing attached, ran tiller, ran mower long time.
Only issue is with mower there is a sound caused by harmonics.
I always use hearing protection due to my sunroof amplifying noise so not big deal. I'll use stethoscope in a bit and put a 5\16 bolt in one of the cooling holes to interrupt the harmonic frequency.
/ mounted retail rems sentinel plate on 2010 GC2400 today #7
Ok, now that I am understanding, that doesn't sound so bad.
Lou
did hit small issue, when fully raised mid mount mower gearbox, trailing edges,driveshaft clears everything. however drive across a bumpy field at full speed with deck up gearbox of deck CAN (depending on how lift links adjusted) bump leading edge of shield and warp it towards 4wd driveshaft. since that rotates whenever front tires move its noticeable noise.
trimmed a little off leading edge and adjusted, think should be good to go. will know next time I put deck on.
no protection was lost by this.
3 hours of mowing yesterday zero interference.
damn. 3 hours of mowing yesterday.
/ mounted retail rems sentinel plate on 2010 GC2400 today #10
Well shoot, that's me once a week!
LOL this was twice in 5-6 days. mowed last thursday and friday (also a 3 hr one due to weather) and mowed yesterday, friday 9-8-23.
normally can do the 1.1+ acres, including steep ditch banks/etc, in 90 minutes. just heat wave over last week caused grass to grow almost 4 inches in 6 days
/ mounted retail rems sentinel plate on 2010 GC2400 today #12
Gotcha.
it was so bad I borrowed neighbors 50 inch husquevarna pull behind sweeper, adapted a 2" (class 3) receiver ball mount hitch to work with his pin type (normal lawn tractor crap) hookup, tossed that into the tractor receiver hitch, adjusted everything for height, bagged a crap load of cuttings up to mix into my large compost pile.
first time in 23 years I bagged grass here.
and I only went over 2/3 of the area I mowed.
next time it needs it I'll buy (and by that I mean my wife will buy for me LOL ) a pto driven bagger. wish the 60" MMM offered a mulch kit.
edit: I see I did not mention WHERE I trimmed.
I trimmed right behind the first set of airflow holes, approx 2" from front of guard and then took approx 3/4" off right hand side of guard using the notch as a guide. transaxle end of guard not touched, only front section of notch touched. guard still rises up and runs along driveshaft.
this was only to make sure guard met MY needs for MY tractor. other brands would not allow this.
did see there was possibility of, if bad crap happens, very slight chance of directional pedal spring getting messed with. just took the 90 deg angle there to a 45 deg angle, removed very small piece. that was just a precaution, had not happened but the ditch angles I work with ....one front tire off ground, rear tire on opp side off ground. diff lock used often. possibility of frame twist so ....precaution.
30in. Forks and Frame Mini Skid Steer Attachment (A59228)
30in. Forks and...
2023 Top Air ATV 200 Gallon Pull Type Sprayer with 30ft Booms (A61307)
2023 Top Air ATV...
(2) UNUSED 31" X 8 MM EXCAVATOR TRACKS W/ PINS (A60432)
(2) UNUSED 31" X 8...
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
UNUSED X-STAR 250 GALLON FUEL TANK W/ FORK POCKETS (A60430)
UNUSED X-STAR 250...
(15) WOOD PALLETS (A60432)
(15) WOOD PALLETS...
