1210 Ford S723 motor swap to a S753
   / 1210 Ford S723 motor swap to a S753 #1
HurriCain
Ford 1210
Does anyone know for sure. Will a Shibaura S753 bolt right into a Ford 1210 in exchange of a Shibaura S723. I have a 1210 Ford with the S723 in it which has a broken crank. The crank is not available (discontinued). I found a S753 out of a Ford Mower. Motor looks the same but not sure about where the flywheel bolts up to crank, etc, etc. Please help. Anyone done one?
TIA
   / 1210 Ford S723 motor swap to a S753 #2
Is the engine out of a CM224 mower? It should bolt up. The S753 was also used in the 1220 - 1.0L. The S723 - 0.9L
   / 1210 Ford S723 motor swap to a S753 #3
yes. Just different bores.
Yes it is. Yes, I saw where the S753 was used in the 1310 tractors. Thank you. The big concern I had was if the flywheel and clutch would work off of the 1210 (S723) on the S753.
   / 1210 Ford S723 motor swap to a S753 #6
Same crank in both 1210 and 1310 so flywheel will work.
OK> Great. I saw where stroke was same but couldn't find dia. of main and rod journals. Yee Haa.
One more question. Can pistons/rods be pushed down in block with head on it to get crank out without pulling head. Those spacers or whatever they are called on main bearing looks BIG.
   / 1210 Ford S723 motor swap to a S753 #8
If I remember right, yes, you can push the pistons into the head to get enough clearance to pull the crank.
Thanks. That will be the plan.
John Deere 4520 Tractor (A50514)
John Deere 4520...
UNUSED CFG Industrial MH12RX Mini Excavator (A47384)
UNUSED CFG...
Grady-White 17ft Fishing Boat with T/A Boat Trailer (A50324)
Grady-White 17ft...
2010 Case 650L Crawler Tractor Dozer (A50322)
2010 Case 650L...
2015 Infiniti QX60 SUV (A50324)
2015 Infiniti QX60...
2005 Sterling Single Axle Dump (A47384)
2005 Sterling...
