LS SAYS A REGEN EVERY 2 HOURS IS NORMAL (Update) 600hrs, 50 regens
   / LS SAYS A REGEN EVERY 2 HOURS IS NORMAL (Update) 600hrs, 50 regens
another regen today while stump grinding, 442 hours on the meter, 7 hours since the previous regen
was grinding, so 2400, but various between 1800 and 2400 since the last regen, with lots of grinding, so a lot of time in the upper range of that.
I sent my dealership the latest information last week, as they were having onsite training with LS, and they were discussing my issue (which has been done before) and received some interesting information this morning...
...the ECU needs to be reprogrammed, my understanding it is attempting to meet Tier V emission standards. your engine is a Tier IV. The reprogramming should solve the issue. Our LS service manager would like to do the programming, so we need to coordinate timing...
Sounds interesting, especially since I am on my 2nd ECU (same problem), but it's definitely worth a shot.
   / LS SAYS A REGEN EVERY 2 HOURS IS NORMAL (Update) 600hrs, 50 regens #195
Just because you have a "new" ECU doesn't mean it was programmed correctly.
Sounds like at least they are aware of the issue and trying to deal with it.
Best of luck! Keep pressing them.
   / LS SAYS A REGEN EVERY 2 HOURS IS NORMAL (Update) 600hrs, 50 regens #196
Wow, I just turned 402h on my T474. I have not had a requested regen YET.
   / LS SAYS A REGEN EVERY 2 HOURS IS NORMAL (Update) 600hrs, 50 regens #197
   / LS SAYS A REGEN EVERY 2 HOURS IS NORMAL (Update) 600hrs, 50 regens #198
402 hours and you haven't had a single regen?
I'd say it has regen'd a few times while he was running it high enough RPM's he just didn't notice the regen happening.
   / LS SAYS A REGEN EVERY 2 HOURS IS NORMAL (Update) 600hrs, 50 regens #199
I usually work between 1800-2400 (pto speed) most of the time. And it must work just fine with passive regen? My machine has been 100% reliable to this point.
   / LS SAYS A REGEN EVERY 2 HOURS IS NORMAL (Update) 600hrs, 50 regens #200
Mine just did it's first a few days ago at 29hrs. There had been quite a bit of idle time.
2004 FORD F-350 SUPER DUTY (INOPERABLE) (A58214)
2004 FORD F-350...
7ft Metal Shell Pump (A57454)
7ft Metal Shell...
2002 TOYOTA 7FDKU40 FORKLIFT (A57880)
2002 TOYOTA...
2007 Jeep Liberty 4x4 SUV (A56859)
2007 Jeep Liberty...
2013 TEXAS PRIDE LAY FLAT HOSE TUGGER TRAILER (A58214)
2013 TEXAS PRIDE...
2022 CATERPILLAR D4 LGP CRAWLER DOZER (A52709)
2022 CATERPILLAR...
