Good morning!!!!
   / Good morning!!!! #175,961
73°F and rain this morning, only got up to 81° today. Rained here pretty much all day. Lots of rumbles through the day, but no severe stuff. Stopped for a bit, and the skies started to clear up nicely shortly before sunset, but more coming overnight tonight, starting in a few minutes.
The rain put the kibosh on outdoors stuff, so Wife and I did our piddling on indoors stuff. I also got in a nap that fell just short of epic.
Guess we'll see what tomorrow brings.
Hope everyone is well.
Good evening, gents.
   / Good morning!!!! #175,962
Drinking hot cup of coffee. 51° with clear skies this morning. Heading to 71° with lots of sun. Bought a jump seat for my Mule SxS. It was on back porch when I let Sassy out yesterday. Spent way to much time assembling it and making adjustments to make it fit my Mule. In afternoon helped neighbor remove some big limbs that were hanging in his trees. Then stayed up way to late watching NASCAR race. I can still hear generators running from Wednesdays storm. About all I plan to get done today is mow grass when it dries.
Prayers and and best wishes for everyone.
Good Morning All.
   / Good morning!!!! #175,963
good morning all
63 headed up to mid 80's today, should be nice
lots of outside work planned for today
going to clear out garden and get rid of overgrown tomato vines that aren't producing much
my tomatoes came in early, had plenty, but the later vining tomatoes aren't happy at all.
Last year they kept producing, not this year.
and more bugs invaded; this batch was promptly hosed down with neem oil and no longer
Dennis, I bet those tomatoes were scooped right up at church.
every day is an opportunity for kindness
Don, has your garden survived the heat with irrigation or have cutbacks done them in?
that video of the crunchy grass was amazing. I've never seen ground crack like that.
   / Good morning!!!! #175,964
RNG, this is for you.
who would think your favorite rose bush could burn your house down...
metal roof makes a lot of sense and I thought the idea of putting screen mesh over all openings
was important. I think most would be covered anyway, to keep out the critters, but now that screen is even
more important
of course keeping everything noncombustible within a couple hundred feet of your house sure does a number
on landscaping with plants and shade trees.
maybe we could get some artificial fireproof trees... :rolleyes:
I was thinking of the early inhabitants of that hot area, likely living in Adobe homes.
and no local landscaping. The American Indians had it right.
Or they would take down a teepee and hustle out of there.
had to look that up. Tipi: Lakota for dwelling
I grew up in the woods, woods came up to back yard of house. Never worried about it.
We get enough rain here in Eastern PA there is rarely a drought.
Fire company did have to come once to put a small brush fire out in our woods, 50 years ago.
I don't remember what started it. Thankfully we had a small bulldozed forest road down to the stream in the middle of the woods
and the fire company brush truck was able to drive down that.
Now if I were over in the NJ Pine Barrens, this becomes very real.
Sorry you folks in Texas and S/W are so hot. Dangerous for older folks and you get stuck inside when you want to
go out. Along with other spares, sounds like having spare hvac capacitors is a good idea.
at least you don't have power problems this year.
temps here have been average to I think below average for August.
probably means it's overly hot somewhere else due to some blocking high or whatever, or position of jet stream.
nice to know why but you can't do much about it...
   / Good morning!!!! #175,965
Good Morning!
God has given us another chance to get it right (or at least not screw up too badly).
65Fgoing to low 80s, afternoon thunderstorms forecasted through the evening.
Good day up at the woodlot. We planned on being out around noon, finally left almost 2PM. Mrs. handled the wood splitter solo for the first time, and stacked a pallet three feet high. I cleared another path trying to get a good path to bury irrigation pipe, but hit into a nest of some sort of flying insect (not stingy, just a CLOUD of them) so advanced in a different direction and worked on another walking path, then did the 50-hour Drive Motor oil change at 49.2 hours. I also installed a locking grease gun nozzle— and WOW what a difference it makes compared to the standard spring type— and greased the ring gear and swing motor. I think I would like to get one of those 4-ft grease gun hoses so I don’t have to attach to fitting, pump grease, detach from fitting, climb into cab, swing 45°,climb out of cab, walk around to other side, attach to fitting, pump grease, detach from fitting, etc…
at least with the long hose I can attach once and pump from the cab through the whole 360° rotation, then get out ONCE and switch to the other grease fitting.
Finished up the day with an evening fundraising concert put on by the Rotary at the local brewery, did not win the 50/50 —% the guy behind me did, but he bought over $100 worth of tickets…
church shortly, quick run to woodlot to run genny and pump for irrigation for a bit, then running to Big Town with the Doggos to Petsmart for bath and brush outs and nails etc.
I hope everyone has a happy healthy safe blessed day!
   / Good morning!!!! #175,966
Good Morning
67 with a high of 80 today
Clear skies and gentle winds
In other words, a perfect day.
Yesterday was a slow day. Mostly cleaning up around the shop, moved some hay from the shed to the barn, did a little lathe project, picked up some hardware at TSC, never did the compressor, that will be this morning. An old friend came by with an RC model to fly, his first time in over a decade, so he wanted me nearby as a safety. He did fine, plane went home in the same condition it arrived. Short visit with son, grandson and DIL before calling it a day.
Today will be the compressor, maybe some paperwork, and hopefully a visit the RC club. And a quick walk with the string trimmer.
   / Good morning!!!! #175,967
74 and a nice welcome wet morning...nearly 1.5 inches of rain overnight, and while I was outside this morning. Ground soaked it up and grass is already perking up, where it isn't brown.
Lou, looks like that fair would have been a great time. Love those Olivers.
RS, this is one of the best buys I've found at HF...48" floor scraper...I use it to scrape parts of the mower deck without crawling under it...they also have one with a shorter handle where the long one is too long to get an angle. I also keep a putty knife handy for close quarters.
   / Good morning!!!! #175,968
Picked up old Z turn good as new, push mower new carb, 30 in walk behind new cables belts, Z Turn new belts one pump new blades, leaf blower and FS130 new carbs what’s up with new carbs?
70 high in 80s today hope for rain. SE might get good dose later in the week from TS will see. Next week going to be nice temperature wise locally
Nap sounds nice PJ
Nice ride mostly
bet painting looks good wngsprd I know you miss hikes
Sorry about tomatoes Drew
Race was exciting Ron just read about nasty wreck
Prayers for all our Country
   / Good morning!!!! #175,969
62F partly cloudy day low 70's for high.
Outside chores done E muffin time. :)
Nice to watch 4 gray fox pups chasing one another from front field to side field back and forth while barking, 3 out of 6 deer weren't amuse charge pups.
Plans for today...check game cams,trim several low hanging limbs,clean critter feeding area and putter.
Enjoy your day all.
   / Good morning!!!! #175,970
Putter sounds wonderful Thomas
LOT: (2) Rolling Nut & Bolt Carts w/Bins & Contents (A59076)
LOT: (2) Rolling...
New/Unused CFG Industrial H15R Mini Excavator (A57453)
New/Unused CFG...
JOHN DEERE 310K (A58214)
JOHN DEERE 310K...
2020 Ford F-150 4X4 Ext. Cab Pickup Truck (A55973)
2020 Ford F-150...
AM GENERAL M1123 HMMWV 2 DOOR TRUCK BODY (A58214)
AM GENERAL M1123...
Air Compressor (New/Unused) (A59225)
Air Compressor...
