Frost plug heater troubles
/ Frost plug heater troubles #1
Hulapopper
Satoh buck
New to forum. I'm trying to replace a frost plug heater on a satoh buck. It is a Katz brand. Unable to remove old one from block, any tips or tricks? Missing in pic is plastic cover and wiring.
New to forum. I'm trying to replace a frost plug heater on a satoh buck. It is a Katz brand. Unable to remove old one from block, any tips or tricks? Missing in pic is plastic cover and wiring. View attachment 818081
Could this be moved to the satoh forum, newb mistake.
/ Frost plug heater troubles #3
That almost looks like a press fit but I have never seen a press fit block heater. Do you have a replacement heater to look at for reference on how it installs?
I do not have a replacement yet. Need a measurement. Original is a thicker steel, not brass like most new ones.
/ Frost plug heater troubles #5
That center bolt wouldn't operate the wings on the back side by any chance, similar to a toggle bolt. If it is, a tap on the bolt should knock the wings free. Any frost plug block heater I've ever seen typically uses the same type of clamping arrangement, not saying this one isn't different somehow. Hopefully someone with more experience will chime in.
/ Frost plug heater troubles #6
You could try prying on the bolt or you can take a punch and knock it loose.
It does. Knocked the wing into water jacket.
Cannot get anything in there to pry. I have smacked it with a punch.
/ Frost plug heater troubles #11
If had wing type toggle bolt it will not drive out since has shoulder on to allow toggle to tighten up. You may have to drill a couple holes in it and pry it out.
/ Frost plug heater troubles #13
Probably gonna have to work at it by driving a flat screwdriver into the fitting so it can be distorted and ripped out.
If you show me a threaded freeze plug hole, I'll buy you a happy meal. How could it freeze and pop out if it's threaded?
Some other freeeze plugs in there only 1/2 diameter. I didn't know if this was specifically for a block heater.
/ Frost plug heater troubles #18
For installing a freeze plug we used a socket to tap them in. I have only seen block heaters that have threads to hold them in.
willy
/ Frost plug heater troubles #20
Glad the OP got the heater out!
I have seen threaded "freeze" plugs, as well as threaded plugs in the water jackets.
Ford Pickup Truck Bed (A61573)
Ford Pickup Truck...
Wolverine Quick Attach Tiller (A66285)
Wolverine Quick...
2020 INTERNATIONAL LT625 48" SLEEPER (A62613)
2020 INTERNATIONAL...
FRIGIDAIRE GALLERY REFRIGERATOR/FREEZER COMBO (A64281)
FRIGIDAIRE GALLERY...
2020 International HX620 Quint Dump (A62613)
2020 International...
UNUSED WOLVERINE BUCKET (A64281)
UNUSED WOLVERINE...
