TYM T25 this thing is amazing!!!
   / TYM T25 this thing is amazing!!! #34
Has anyone compared the T25 to the 2515 models?
I got a 2515R but I’ve heard a lot about how people just love their T25’s as well as the 2515 guys love theirs.
   / TYM T25 this thing is amazing!!! #35
The 2515 is pretty much two times the T25 just about in every spec other than HP.
   / TYM T25 this thing is amazing!!! #37
As the gentlemen above me posted, the 2515 is in a whole different class. They're both great machines, but the 2515 is on the larger end of the Compact Utility Tractor or CUT spectrum, where the T25 is on the smaller end. Hell, some would argue that the T25 is a large Sub-Compact Utility Tractor, or SCUT. That puts is closer to the (legacy Branson) TYM 2610h, which while a nice machine, is a generation behind the T25 with regards to operator comfort.
The T25 is going to be quicker than the 2515 due to it's better power-to-weight ratio, but the larger machine will outperform the T25 in any task that hydraulics and weight will benefit.
Obviously, you need one of each. 🤣
   / TYM T25 this thing is amazing!!! #38
TYM considers the T25 a Tier 1 (Subcompact), but the '15 series' machines are Tier 2 (smaller compact tractors) The 2515 is even slightly lighter than the T394. The T25 is like 1000lbs lighter. Almost like trying to compare a sedan to a small pickup. Different roles.
   / TYM T25 this thing is amazing!!! #39
^^^Cool.
Thanks for the info.
LOT: Receiver Hitches, 1/2 Ton Sheet Clamp, Pipe Threader (A59076)
LOT: Receiver...
2020 4-Fuel 800 Gallon Fuel Tank, Model 4F-838, S/N 4F-838811/20, Nominal Capacity, 838 Gallon/3172 (A59076)
2020 4-Fuel 800...
2017 Freightliner Cascadia 125 T/A Sleeper Cab Truck Tractor (A56858)
2017 Freightliner...
PumpJack Brand Pump Jack (A56436)
PumpJack Brand...
(APPROX 15) 6"X2"X68" TUBING (A58375)
(APPROX 15)...
*NEW* 50 Traffic Cones (A55272)
*NEW* 50 Traffic...
