Del morino v-belt installation
   / Del morino v-belt installation #1
redcar98
Virginia
JD 2720
As anyone used a stretch belt installer tool to install new belts on a Del morino flail mower?
   / Del morino v-belt installation #2
Hello redcar98,
What model Del Morino Flail Mower do you have?
You may have a great deal of fine dust in the adjuster track that is preventing the
adjuster from fully releasing to allow you to install the V belts if they are the correct ones.
If you have fully released the snubber pulley and you cannot slip the V belt(s) on
the small pulley and then the larger pulley you may have been sold the wrong V-belts.
You only need hand tools to release the tensioner/v-belt snubber for
the V-belts otherwise you will ruin the new belts.
Loosen the V belt tensioner completely and then place the V belts on
the pulleys and then adjust them.
Do you have a V belt tensioning gauge??? If not, you should have one in your tool box.
   / Del morino v-belt installation #3
If you have fully released the snubber pulley and you cannot slip the V belt(s) on the small pulley and then the larger pulley you may have been sold the wrong V-belts.
I don't know about the OP's Del Morino, but on my Peruzzo that is not true, as the dealer has verified. With the tensioner pulley fully released you still have to roll the belts on under tension.
From experience, I can tell you that one in three old belts will snap when trying to re-install even with the tensioner fully released.
   / Del morino v-belt installation #4
Hello redcar98,
I just got a Del Morino Flipper flail mover. FLI 214 MMSS. What would one set the tension to or how would you figure it out? The manual basically says adjust it correctly. It is a 3 belt drive.
JOHN DEERE/UNVERFERTH 1700/330 (A53084)
JOHN...
30in Forks and Frame Mini Skid Steer Attachment (A55851)
30in Forks and...
2019 PJ TRAILER 32FT GOOSENECK (A55745)
2019 PJ TRAILER...
2010 John Deere TX Gator 4x4 Utility Cart (A52377)
2010 John Deere TX...
Hose Reel (A55758)
Hose Reel (A55758)
Kubota BX2680 Sub-Compact Tractor  4WD, 218 Hours (A55301)
Kubota BX2680...
