Oct 18, 2021 / Kubota gf1800 #1 C Cort Stubbert New member Joined Oct 18, 2021 Messages 1 Tractor Kubota gf1800 Throttle lever
Oct 18, 2021 / Kubota gf1800 #2 Roadworthy Elite Member Joined Aug 24, 2019 Messages 4,060 Location Southeast Washington Tractor Kubota L2501 HST, If there's a question somewhere there you'll have to elaborate a bit. Oh, and welcome to TBN.
Oct 18, 2021 / Kubota gf1800 #3 ljjhouser Veteran Member Joined Oct 25, 2018 Messages 1,389 Location Midwest - Ozarks Tractor Kubota L4701 Increases engine rpm - if it works. welcome to TBN.
Aug 12, 2023 / Kubota gf1800 #4 jimmydjack New member Joined Aug 12, 2023 Messages 2 Tractor Kabota g 1800 New ignition switch for g 1800 kabota
Aug 12, 2023 / Kubota gf1800 #5 jimmydjack New member Joined Aug 12, 2023 Messages 2 Tractor Kabota g 1800 How hard to do and where to buy?
Aug 13, 2023 / Kubota gf1800 #6 R Richard001 Veteran Member Joined Jun 25, 2015 Messages 1,867 Location Plymouth, MN Tractor Jd lx178 jimmydjack said: How hard to do and where to buy? Click to expand... Google this: ignition switch for g 1800 kubota About 1,580,000 results (0.48 seconds) From Amazon: https://www.amazon.com/s?k=kubota+g1800+ignition+switch&hvadid=580745848256&hvdev=c&hvlocphy=9019484&hvnetw=g&hvqmt=e&hvrand=7097922950499805954&hvtargid=kwd-339797122002&hydadcr=17795_13467253&tag=googhydr-20&ref=pd_sl_79wdhqpnrn_e If you have access to the back of your dash, then it should be a rather easy fix. Note that some of the switches offered have different connectors. Check the connector on you machine and make sure the one you order has the same connector. Richard
